Doepfer
Doepfer A-152 question
2008-12-28 by RMC
Hello
I'm starting to build up a single 3U rack, having been away from
electronic music for the last couple of years due to house moves and so
on. I have an MFB SEQ-01 trigger sequencer and a couple of Doepfer
modules, namely the A-156 quantiser and the A-163 VC divider so far.
I've read the PDF manual for the A-152 module but I haven't understood
it properly. Can I use the A-152 as an analogue shift register (ASR)
with a shift length of more than three stages i.e. upto 8 stages?
I understand the T&H or S&H aspects and the 1-8 mux but not the ASR
aspects.
In fact, has anyone got some demo MP3 tracks using the A-152 as a shift
register that you could point me to please?
Thanks for any pointers
RMC, England
A-132-3
2008-12-28 by Pieter Volger
I have atm two old A-131 VCA's as outputs. I want to expand the system
to 4 outputs. How is the quality of the A-132-3 compared with the old
A-131. I am not sure wether I keep the old 131 or buy two A-132-3 for
four outputs.
Thanks for any suggestions.
Pieter
Re: [Doepfer_a100] Doepfer A-152 question
2008-12-28 by Bakis Sirros
no, the A152 is not a true ASR.
it distributes the incoming voltage (from its S/H input) to its 8 S/H outputs, in each clock pulse, or everytime a new step is addressed (via the address knob and cv input).
in detail, the last voltage level, presented in the S/H input, is held, when a new step is addressed.
but, that voltage is not proceeding to the next s/h output, as it is the case in a true ASR.
despite that, the A152 can be used for some really great effects!
[Doepfer_a100] group owner
www. parallel - worlds - music. com
www. myspace. com/ parallelworldsmusic
www. myspace. com/ interconnectedmusic
www. myspace. com/ memorygeist
www. DiN. org. uk
www. musicamaximamagnetica. com
www. shimarecords. co. uk
www. rubberrecords. gr
Athens - Greece
--- On Sun, 12/28/08, RMC <electronicbattle@googlemail.com> wrote:
Subject: [Doepfer_a100] Doepfer A-152 question
Date: Sunday, December 28, 2008, 12:33 PM
            Hello
aspects.
RMC, England
2008-12-28 by Axel Jungkunst
Of course you can use the A-152 as an ASR, there is an
example patch called Mono-Poly-Converter, which is nothing
else than an ASR function.
Greets
Axel
> www. DiN. org. uk
> Athens - Greece
> <mailto:electronicbattle%40googlemail.com>> wrote:
> From: RMC <electronicbattle@googlemail.com
> To: Doepfer_a100@yahoogroups.com <mailto:Doepfer_a100%40yahoogroups.com>
> Hello
> aspects.
> RMC, England
nope.
this is still not a true ASR.
www. DiN. org. uk
Athens - Greece
--- On Sun, 12/28/08, Axel Jungkunst <phaedra@t-online.de> wrote:
Subject: Re: [Doepfer_a100] Doepfer A-152 question
Date: Sunday, December 28, 2008, 1:08 PM
example patch called Mono-Poly-Converter , which is nothing
Greets
Axel
> www. DiN. org. uk
> www. musicamaximamagneti ca. com
> Athens - Greece
> --- On Sun, 12/28/08, RMC <electronicbattle@ googlemail. com
> <mailto:electronicb attle%40googlema il.com>> wrote:
> From: RMC <electronicbattle@ googlemail. com
> To: Doepfer_a100@ yahoogroups. com <mailto:Doepfer_ a100%40yahoogrou ps.com>
> Hello
> aspects.
> RMC, England
How in your opinion does a "true" ASR work?
> nope.
> www. DiN. org. uk
> Athens - Greece
> <mailto:phaedra%40t-online.de>> wrote:
> From: Axel Jungkunst <phaedra@t-online.de <mailto:phaedra%40t-online.de>>
> Greets
> Axel
> > www. DiN. org. uk
> > Athens - Greece
> ps.com>
> > Hello
> > aspects.
> > RMC, England
Now I see the error in your explanation: the incoming voltage is not
distributed to all
8 S/H outputs, but to the first one. Each incoming pulse shifts it one
S/H-Output further
and fills the first one with the new state.
You can terminate the number of outputs by using a digital out to the
reset in (look at the example).
Try it out, I've done it, it works fine.
best regards
Axel
> www. DiN. org. uk
> Athens - Greece
> Hello
> aspects.
> RMC, England
2008-12-28 by John V. Talbert
While we're discussing the A-152, I'd like to ask a question here if I may.
I've never had the opportunity to work with an A-152 type module and
I'm wondering how useful it might be to add to my setup.  From the
patch in the video, only an A-152 and an A-160/161 pair are listed for
sequencing.  I understand how the A-160/161 are used for the
percussion, but it escapes me how an A-152 alone could be used as a
sequencer for this particular sequence.  Wouldn't the pitch voltage
for the base sequence need to orginate from some other repeating
source?  (otherwise the voltage would eventually "disappear" at the
last step, right?)  And wouldn't there also need to be some other
stepped source to provide the 4 modal changes?  Maybe I'm still not
clear how this module works.  Perhaps someone with more experience
with this module could shed some light?  Right now I'm a bit fuzzy.
John
> distributed to all
> S/H-Output further
> best regards
> Axel
Re: Doepfer A-152 question
2008-12-28 by Doug
Hi John, the "digital outputs" section of the A-152 can be used with a
mixer to create an 8 stage sequencer (just like you would with the
A-161 or A-149-2). You can increment the step using the 152 clock
input. You can also use the cv input to make the steps go backward, or
forward, or completely random.
The A-152 is doing the four modal changes. The A-160/1 does the faster
8 step repeating part.
Doug
2008-12-28 by Doug
What you are describing is great, and would constitute an ASR, but it
doesn't match the factory description:
"The signal at the common T&H input is connected to the addressed T&H
output. As soon as a new output is addressed the last voltage is
stored at the output (Track&Hold function)."
> distributed to all
> S/H-Output further
> best regards
> Axel
Re: [Doepfer_a100] Re: Doepfer A-152 question
But it matches my patching, try it out!
> <mailto:Doepfer_a100%40yahoogroups.com>, Axel Jungkunst <phaedra@...>
> > distributed to all
> > S/H-Output further
> > best regards
> > Axel
no, each incoming pulse DOES NOT shift it one
S/H-Output further and DOES NOT fill the first one with the new state.
with each incoming pulse, the voltage of each output remains in the step it was, and the new voltage fills the next S/H output.
that's why it is not a true ASR.
www. DiN. org. uk
Athens - Greece
Date: Sunday, December 28, 2008, 1:27 PM
distributed to all
S/H-Output further
best regards
Axel
> www. DiN. org. uk
> Athens - Greece
> Hello
> aspects.
> RMC, England
exactly.
the factory description is correct.
so, the A152 is no a true ASR.
we have tried it when i was in Ingo Zobel's studio and we confirmed Ingo's saying.
(i too was initially confused and thought that the a152 was an ASR, but i was wrong, as Ingo showed to me.)
www. DiN. org. uk
Athens - Greece
--- On Sun, 12/28/08, Doug <dougc356@yahoo.com> wrote:
Subject: [Doepfer_a100] Re: Doepfer A-152 question
Date: Sunday, December 28, 2008, 8:33 PM
> distributed to all
> S/H-Output further
> best regards
> Axel
i thought that too initially, but:
let's say that a true ASR's steps are empty of voltages.
first step is filled with voltage 'X'.
in the next trigger, that voltage 'X' is moved to step two and a new voltage 'Y' fills the first step. in the next trigger, the voltage 'X' fills the step three, the voltage 'Y' fills the step two and the new voltage fills the first step. that's how a true ASR works.
so, in a true ASR, the new voltage fills the first step and the older voltages go down one step in the chain.
the A152 fills the first step with the last present voltage in it, when a clock pulse was received, or a new step was addressed. the currently present voltage, that is now in the second step, will fill the SECOND step, with the exact value it had when the clock pulse was received, after a new clock pulse is received. then, the currently presented voltage that is in the third step now, at the next clock pulse, will fill the THIRD step with its exact value when the clock pulse was received. also, each output tracks the current voltage until a clock pulse is received, so it is a T/H and not a S/H unit.
so, in the A152, the new voltage fills the NEXT step and the old voltages remain at the steps they were.
www. DiN. org. uk
Athens - Greece
Subject: Re: [Doepfer_a100] Re: Doepfer A-152 question
Date: Sunday, December 28, 2008, 9:18 PM
> <mailto:Doepfer_ a100%40yahoogrou ps.com>, Axel Jungkunst <phaedra@... >
> > distributed to all
> > S/H-Output further
> > best regards
> > Axel
2008-12-29 by Axel Jungkunst
Thanks for your explanation, you are right, so the "ASR"-effect of the
A-152 has a one-step-delay
to an original ASR, but the shifting of the states works as derscribed,
so, by example, you can
fill the cv output of sequencer to the A-152 input and feed oscillators
with the state of the T/H-registers while
clocking the A-152 with the clock out of the sequencer.
Here you can build polyphonic sequences and you are more flexible: for
example you can patch three
outputs of T/H to an OSC each, but you are able to use a range of six
steps by using the reset-in from a digital out
and patch the T/H outputs 1,3 and 4 to the osc to build interesting
tonal models.
Again, the only difference is one step too late, but it is the same kind
of problem as you
have with sequencers, which are resetting to the last or to the first step.
You have to accept these circumstances and nobody will hear that you are
not using an original concept of a so-called true ASR,
but a delayed one ;-)
There is  a technical aspect and I'm looking at the musical aspect.
The audio examples from Plan B's Model 23 can be realized with the A-152.
best regards
Axel
> www. DiN. org. uk
> Athens - Greece
> <phaedra@... >
> > > distributed to all
> > > S/H-Output further
> > > best regards
> > > Axel
2008-12-29 by Bakis Sirros
hello Axel,
no, this is not a matter of a 'one step delay'.
its quite different.
please, re-read my detailed explanation and you'll see what i mean.
in a true ASR, the voltage of each step changes with each clock trigger.
in the A152, the voltage of each step remains the same until its turn comes to hold the currently presented voltage (when addressed, via the address knob and cv input, or the clock trigger)
i hope Ingo Zobel maybe can explain it a bit clearer? Ingo?
that said, the A152 is a great module that can do many things! it is just Not a true ASR.
www. DiN. org. uk
Athens - Greece
Date: Monday, December 29, 2008, 8:24 AM
tonal models.
of problem as you
best regards
Axel
> www. DiN. org. uk
> Athens - Greece
> --- On Sun, 12/28/08, Axel Jungkunst <phaedra@t-online. de
> <mailto:phaedra% 40t-online. de>> wrote:
> From: Axel Jungkunst <phaedra@t-online. de <mailto:phaedra% 40t-online. de>>
> <phaedra@... >
> > > distributed to all
> > > S/H-Output further
> > > best regards
> > > Axel
Hi Bakis,
you're so right, thanks having taken the time.
I think I have to buy a Model 23 from Plan B.
But you're also right that the A-152 has great functions.
I worked the last hour with it to see what you mean.
best regards
Axel
> hello Axel,
> www. DiN. org. uk
> Athens - Greece
> tonal models.
> of problem as you
> step.
> best regards
> Axel
> > www. DiN. org. uk
> > Athens - Greece
> 40t-online. de>>
> ps.com>
> > <phaedra@... >
> > > > distributed to all
> it one
> > > > S/H-Output further
> to the
> > > > best regards
> > > > Axel
2009-01-09 by achtung_999
Thanks for this great discussion guys!I was just wondering about the A152 in
comparison to the Model 23 from plan B.
You really saved me a lot of think work.
Greetings,
Ernst
On Mon, Dec 29, 2008 at 7:30 PM, Axel Jungkunst <phaedra@t-online.de> wrote:
>   Hi Bakis,
> best regards
> Axel
> > hello Axel,
> > www. DiN. org. uk
> > Athens - Greece
> > --- On Mon, 12/29/08, Axel Jungkunst <phaedra@t-online.de<phaedra%40t-online.de>
> > <mailto:phaedra%40t-online.de <phaedra%2540t-online.de>>> wrote:
> > From: Axel Jungkunst <phaedra@t-online.de <phaedra%40t-online.de><mailto:
> > To: Doepfer_a100@yahoogroups.com <Doepfer_a100%40yahoogroups.com><mailto:
> Doepfer_a100%40yahoogroups.com <Doepfer_a100%2540yahoogroups.com>>
> > tonal models.
> > of problem as you
> > step.
> > best regards
> > Axel
> > > www. DiN. org. uk
> > > Athens - Greece
> > > <mailto:phaedra% <phaedra%25> 40t-online. de>> wrote:
> > > From: Axel Jungkunst <phaedra@t-online. de <mailto:phaedra%<phaedra%25>
> > 40t-online. de>>
> > ps.com>
> > > <phaedra@... >
> not
> > > > > distributed to all
> > it one
> > > > > S/H-Output further
> > to the
> > > > > best regards
> > > > > Axel
