Doepfer
Post 'fuse' weirdness
2009-02-04 by madrayken
After the Monday-of-doom, I replaced my fuse, plugged in my modules.
They seem to work... with one exception.
When I plugged in the A-190, my two oscillators produced nothing but
weird, very low-level ring-mod-y noise.
I tried plugging in the A-190, *without* the AD5 - same problem.
I tried plugging in the AD5 alone - no problem.
1) Has anyone had an A-190 cause this?
2) Could it be a problem with the AD5 instead?
3) Could it be some weird short on the +5v part of the rail instead?
I've no idea what to replace, or whether to look elsewhere in the box
for some other cause.
Any help - as ever - much appreciated.
Dene
P.S. I also found I started getting slight shocks from the case after
use... :-( makes me very nervous.
Re: [Doepfer_a100] Post 'fuse' weirdness
2009-02-04 by Derek Holzer
My simple advice is to get a multimeter and learn how to use it. Check
for shorts between your power rails, and maybe take your problem A-190
and the 5V regulator out of the case and check for shorts between the
power pins there as well. If all this is too much to figure out on your
own, then take it to an electronics specialist and let them do it for
you. Of course, if it's still under warranty you could send it all in
for service.
Best!
D.
> Dene
derek holzer ::: http://www.umatic.nl ::: http://blog.myspace.com/macumbista
---Oblique Strategy # 132:
'Remember .those quiet evenings'
Re: Post 'fuse' weirdness
2009-02-05 by madrayken
One further wrinkle - and please forgive me for my ignorance here.
I can't get the A-190 to do anything at all - i.e. even the menu's are
inoperative.
My A-190, AD5 and oscillators normally live on my top rail, so I the,
to the lower rail.
The same problem occured - but only if I manually patched the CV1 out
to my oscillators. Normally, I'd take that to mean that the AD5 or
A-190 were dead.
So, just for information's sake:
1) Is the A-190/AD5 combination supposed to send gate and CV
information to both rails, or just the one they are attached to?
2) If the AD5 was dead, would that result in a totally inoperative A-190?
3) If the A-190 were dead, would that result in the oscillators on the
same rail receiving stupidly low CV information?
Many thanks for your patience.
> Dene
Thanks, folks.
--- In Doepfer_a100@yahoogroups.com, Florian Anwander <fanwander@...>
wrote:
> Hello
> Just to the one it is attached to.
inoperative A-190?
> Yes
on the
> Yes this might be - but I never tested it ;-).
> I definitely subscribe the recommendation of Derek. Learn a little
bit
> more about electronics and learn to handle a voltmeter.
> Florian
Re: [Doepfer_a100] Re: Post 'fuse' weirdness
2009-02-05 by Florian Anwander
Hello
Yes
I definitely subscribe the recommendation of Derek. Learn a little bit
Florian
