doepfer/asys power adapter
2009-02-15 by Monroe Eskew
There is an adapter made by AS to fit their modules in Doepfer cases. It looks like in theory it could be used for the reverse application, fitting Doepfer modules to AS power sockets. Can someone verify that this works? Thanks, Monroe
2009-02-15 by nicholas_kent
--- In Doepfer_a100@yahoogroups.com, Monroe Eskew <monroe.eskew@...> wrote: > > There is an adapter made by AS to fit their modules in Doepfer cases. > It looks like in theory it could be used for the reverse application, > fitting Doepfer modules to AS power sockets. Can someone verify that > this works? > I'm using the one I bought from from Big City Music and it's fine. I assume it came from ASys. Be extra careful to make sure everything is plugged in the correct orientation and not the reverse. You don't have to do anything unusual, just for instance look at the -12 volt connection on the module and trace it through the adapter cable to the -12 on the ASys case. This is especially true of the couple Doepfer compatible brands that are already easy to install the wrong way. p.s. "AS" isn't such a good abbreviation because Analogue Solutions makes all sorts of Eurorack gear too. I've got an AS rack with a majority of AS sockets but all my AS modules use Doepfer sockets. So I needed to use one of these AS adaptors to connect my AS module to my AS case.
2009-02-15 by achtung_999
I can highly recommend the Analogue Haven adapter.
On Sun, Feb 15, 2009 at 11:39 AM, nicholas_kent <zaum@optonline.net> wrote: > --- In Doepfer_a100@yahoogroups.com, Monroe Eskew <monroe.eskew@...> wrote: >> >> There is an adapter made by AS to fit their modules in Doepfer cases. >> It looks like in theory it could be used for the reverse application, >> fitting Doepfer modules to AS power sockets. Can someone verify that >> this works? >> > > I'm using the one I bought from from Big City Music and it's fine. I assume > it came from ASys. > Be extra careful to make sure everything is plugged in the correct > orientation and not the > reverse. You don't have to do anything unusual, just for instance look at > the -12 volt > connection on the module and trace it through the adapter cable to the -12 > on the ASys case. > This is especially true of the couple Doepfer compatible brands that are > already easy to install > the wrong way. > > p.s. "AS" isn't such a good abbreviation because Analogue Solutions makes > all sorts of > Eurorack gear too. I've got an AS rack with a majority of AS sockets but all > my AS modules > use Doepfer sockets. So I needed to use one of these AS adaptors to connect > my AS module > to my AS case. > >
Can that be used to plug Doepfer modules into ASys sockets? It looks like it is a female ASys + female Doepfer, so it could only be used to plug ASys into Doepfer sockets, since the ASys sockets in the RS10/15 case are female. On Sun, Feb 15, 2009 at 3:39 AM, achtung_999 < heinrich.himmelwasser@gmail.com> wrote: > I can highly recommend the Analogue Haven adapter. > > > On Sun, Feb 15, 2009 at 11:39 AM, nicholas_kent <zaum@optonline.net<zaum%40optonline.net>> > wrote: > > --- In Doepfer_a100@yahoogroups.com <Doepfer_a100%40yahoogroups.com>, > Monroe Eskew <monroe.eskew@...> wrote: > >> > >> There is an adapter made by AS to fit their modules in Doepfer cases. > >> It looks like in theory it could be used for the reverse application, > >> fitting Doepfer modules to AS power sockets. Can someone verify that > >> this works? > >> > > > > I'm using the one I bought from from Big City Music and it's fine. I > assume > > it came from ASys. > > Be extra careful to make sure everything is plugged in the correct > > orientation and not the > > reverse. You don't have to do anything unusual, just for instance look at > > the -12 volt > > connection on the module and trace it through the adapter cable to the > -12 > > on the ASys case. > > This is especially true of the couple Doepfer compatible brands that are > > already easy to install > > the wrong way. > > > > p.s. "AS" isn't such a good abbreviation because Analogue Solutions makes > > all sorts of > > Eurorack gear too. I've got an AS rack with a majority of AS sockets but > all > > my AS modules > > use Doepfer sockets. So I needed to use one of these AS adaptors to > connect > > my AS module > > to my AS case. > > > > > > > [Non-text portions of this message have been removed]
Excuse me. I had not read correctly what you wanted to do. My bad!
On Sun, Feb 15, 2009 at 7:24 PM, Monroe Eskew <monroe.eskew@gmail.com> wrote: > Can that be used to plug Doepfer modules into ASys sockets? It looks like > it is a female ASys + female Doepfer, so it could only be used to plug ASys > into Doepfer sockets, since the ASys sockets in the RS10/15 case are female. > > On Sun, Feb 15, 2009 at 3:39 AM, achtung_999 < > heinrich.himmelwasser@gmail.com> wrote: > >> I can highly recommend the Analogue Haven adapter. >> >> >> On Sun, Feb 15, 2009 at 11:39 AM, nicholas_kent >> <zaum@optonline.net<zaum%40optonline.net>> >> wrote: >> > --- In Doepfer_a100@yahoogroups.com <Doepfer_a100%40yahoogroups.com>, >> Monroe Eskew <monroe.eskew@...> wrote: >> >> >> >> There is an adapter made by AS to fit their modules in Doepfer cases. >> >> It looks like in theory it could be used for the reverse application, >> >> fitting Doepfer modules to AS power sockets. Can someone verify that >> >> this works? >> >> >> > >> > I'm using the one I bought from from Big City Music and it's fine. I >> assume >> > it came from ASys. >> > Be extra careful to make sure everything is plugged in the correct >> > orientation and not the >> > reverse. You don't have to do anything unusual, just for instance look >> > at >> > the -12 volt >> > connection on the module and trace it through the adapter cable to the >> -12 >> > on the ASys case. >> > This is especially true of the couple Doepfer compatible brands that are >> > already easy to install >> > the wrong way. >> > >> > p.s. "AS" isn't such a good abbreviation because Analogue Solutions >> > makes >> > all sorts of >> > Eurorack gear too. I've got an AS rack with a majority of AS sockets but >> all >> > my AS modules >> > use Doepfer sockets. So I needed to use one of these AS adaptors to >> connect >> > my AS module >> > to my AS case. >> > >> > >> >> >> > > [Non-text portions of this message have been removed] > >
