FT: Doepfer A-189-1 VBM for a Doepfer A-137 Wave Multiplier
2009-05-15 by Van Eck
Hello everyone. I am looking to trade my Doepfer A-189-1 Voltage Bit Modifier for a Doepfer A-137 Wave Multiplier (first version). I am located in the United States, and have a Good Trader reputation on the Muff board. Please contact me off-list if interested. Thanks! - Greg VanEck vaneck@gmail.com
2009-05-16 by Richard Scott
the description of this modules mentioned old and new versions? But is there any way to physically/visually distinguish these? For the older version it says: "the pressure sensor is made with conductive rubber located below the position sensor and works not as accurate as the very precise position sensor. The resistance of the conductive rubber changes with varying pressure and causes a variable voltage. But the coherence between pressure and resistance/voltage is not very accurate - except that an increasing pressure will cause an increasing voltage. Even some difference of the pressure sensor behaviour over the length of the manual may be possible as the conductive rubber has tolerances over this length." Richard
2009-05-16 by yahoo@doepfer.de
Please look at our FAQ page: www.doepfer.com > FAQ > R2M/A-198 > How can I distinguish between the old and new version of the manual ? Best wishes Dieter Doepfer
> -----Ursprüngliche Nachricht----- > Von: Doepfer_a100@yahoogroups.com > [mailto:Doepfer_a100@yahoogroups.com]Im Auftrag von Richard Scott > Gesendet: Samstag, 16. Mai 2009 02:56 > An: Doepfer_a100@yahoogroups.com > Betreff: [Doepfer_a100] A-198 question > > > the description of this modules mentioned old and new versions? But is > there any way to physically/visually distinguish these? For the older > version it says: > > "the pressure sensor is made with conductive rubber located below the > position sensor and works not as accurate as the very precise position > sensor. The resistance of the conductive rubber changes with varying > pressure and causes a variable voltage. But the coherence between > pressure and resistance/voltage is not very accurate - except that an > increasing pressure will cause an increasing voltage. Even some > difference of the pressure sensor behaviour over the length of the > manual may be possible as the conductive rubber has tolerances over this > length." > > Richard > > > ------------------------------------ > > Yahoo! Groups Links > > >
2009-05-18 by Richard Scott
thanks, can anyone who has used both tell me how extreme the difference is between the older and newer A-198? - it sounds from the description as if the pressure sensor older one is not really easily playable? Richard yahoo@doepfer.de wrote:
> > > > Please look at our FAQ page: > > www.doepfer.com > FAQ > R2M/A-198 > How can I distinguish between the old > and new version of the manual ? > > Best wishes > Dieter Doepfer > > > -----Ursprüngliche Nachricht----- > > Von: Doepfer_a100@yahoogroups.com <mailto:Doepfer_a100%40yahoogroups.com> > > [mailto:Doepfer_a100@yahoogroups.com > <mailto:Doepfer_a100%40yahoogroups.com>]Im Auftrag von Richard Scott > > Gesendet: Samstag, 16. Mai 2009 02:56 > > An: Doepfer_a100@yahoogroups.com <mailto:Doepfer_a100%40yahoogroups.com> > > Betreff: [Doepfer_a100] A-198 question > > > > > > the description of this modules mentioned old and new versions? But is > > there any way to physically/visually distinguish these? For the older > > version it says: > > > > "the pressure sensor is made with conductive rubber located below the > > position sensor and works not as accurate as the very precise position > > sensor. The resistance of the conductive rubber changes with varying > > pressure and causes a variable voltage. But the coherence between > > pressure and resistance/voltage is not very accurate - except that an > > increasing pressure will cause an increasing voltage. Even some > > difference of the pressure sensor behaviour over the length of the > > manual may be possible as the conductive rubber has tolerances over this > > length." > > > > Richard > > > > > > ------------------------------------ > > > > Yahoo! Groups Links > > > > > > > >
2009-05-18 by yahoo@doepfer.de
> thanks, can anyone who has used both tell me how extreme the difference > is between the older and newer A-198? - it sounds from the description > as if the pressure sensor older one is not really easily playable? > > Richard The difference is the pressure sensor. The old version used a conductive rubber which was not very sensitive compared to the new version which uses an very sensitive FSR as pressure sensor (force sensitive resistor). The position sensor has not been changed. Best wishes Dieter
2009-05-18 by Florian Anwander
Hi Richard > thanks, can anyone who has used both tell me how extreme the difference > is between the older and newer A-198? - it sounds from the description > as if the pressure sensor older one is not really easily playable? I played the old one, and I own the new one and I definitely recommend the new one. Florian
2010-02-06 by Richard Scott
all in excellent condition at around 75% of schnieder's prices. Harvestman Malgorithm 190 euro Doepfer A-137 VC Wave mulitplier 85 euro Livewire Frequensteiner 185 euro Analogue systems RS-350 VC slew limiter 73 euro Analogue system RS20 ringmod and multiple (showing a bit of Paintwear so 70% of AS price = 67 euro. postage extra (from the UK), payment in euro or £££. paypal ok if you add the 3%. offlist please!! Richard -- I am using the free version of SPAMfighter. We are a community of 6 million users fighting spam. SPAMfighter has removed 1480 of my spam emails to date. Get the free SPAMfighter here: http://www.spamfighter.com/len The Professional version does not have this message
2010-02-08 by Richard Scott
Hi the frequensteiner and A-137 are gone. Final price drop on the other modules. thanks Richard > Harvestman Malgorithm 175 euro > Analogue systems RS-350 VC slew limiter 70 euro > Analogue system RS20 ringmod and multiple (showing a bit of Paintwear so > 70% of AS price = 64 euro. > > postage extra (from the UK), payment in euro or £££. paypal ok if you > add the 3%. > > offlist please!! > > Richard -- I am using the free version of SPAMfighter. We are a community of 6 million users fighting spam. SPAMfighter has removed 1480 of my spam emails to date. Get the free SPAMfighter here: http://www.spamfighter.com/len The Professional version does not have this message
2010-03-22 by Richard Scott
I'm quite confused about the description of this module. If the A160 create 6 different rates/divisions from the input which one of these divisions is used for the A161 8 step sequence? And how is that controlled? -- I am using the free version of SPAMfighter. We are a community of 6 million users fighting spam. SPAMfighter has removed 1503 of my spam emails to date. Get the free SPAMfighter here: http://www.spamfighter.com/len The Professional version does not have this message
2010-03-22 by Bakis Sirros
the a161 is controlled by the /1 division of the a160. it just steps thru the 8 gate outs in the original clock speed. Bakis Sirros - Parallel Worlds / Interconnected / Memory Geist [Doepfer_a100] group owner www. parallel - worlds - music. com www. myspace. com/ parallelworldsmusic www. myspace. com/ interconnectedmusic www. myspace. com/ memorygeist www. DiN. org. uk www. musicamaximamagnetica. com www. vu-us. com --- On Mon, 3/22/10, Richard Scott <richard_scott@rwnc.co.uk> wrote:
Subject: [Doepfer_a100] A161 question
Date: Monday, March 22, 2010, 2:21 AM
Get the free SPAMfighter here: http://www.spamfigh ter.com/len
