Doepfer
A-118 white noise not white
2010-01-25 by jalmari3
A-118 white noise sounds dark and filtered. Adjusting "Blue" and "Red" on Coloured noise doesn't give true white noise either. I wonder, if there is a mod to bypass the filtering?
AW: [Doepfer_a100] A-118 white noise not white
2010-01-26 by yahoo@doepfer.de
The A-118 derives the white noise simply by amplifying the noise of the
base-emitter transition of an npn transistor. Each transistor generates a
little bit a different noise. Probably your A-118 contains a transistor with
a more dark noise. Replacing the transistor Q1 may change the noise sound.
Best wishes
Dieter Doepfer
