Doepfer
A-160 Clock Divider modification for Down-counting possible?
2010-11-23 by mbox_online
Is it possible to modify the A-160 clock divider so that it starts with firing all the gates and goes from there? That it counts from the top instead of from the bottom. Now I have to wait say 32 clocks for it to fire the /32 gate for the first time. It would be easier to run multiple clocked devices in sync if they all started on the downbeat.
Martin
Re: [Doepfer_a100] A-160 Clock Divider modification for Down-counting possible?
2010-11-23 by dancemachine
you can achieve this behavior by combining multiple doepfer modules.  invert
the clock output that you want to use, then using VCAs and mults of signals
like run/stop and a start pulse you can get the behavior you are looking
for.  others may be able to chime in with specific patches.  I haven't had
run/stop or a start pulse available yet to mess around with this stuff.
 DIN-sync has some of these signals which I may tap into to get more
functionality in this area, if I cannot hold out for the STG stuff to come
out slowly but surely.  I think the 4ms RCD does this out of the box as
well.
> Martin
AW: [Doepfer_a100] A-160 Clock Divider modification for Down-counting possible?
2010-11-23 by yahoo@doepfer.de
> Martin
The A-160 uses a standard CMOS counter (CD4024) that cannot be modified.
Maybe adding inverters do the job you are asking for . In this case all
(inverted) outputs will turn high on each reset.
Best wishes
Dieter Doepfer
Re: AW: [Doepfer_a100] A-160 Clock Divider modification for Down-counting possible?
2010-11-23 by Florian Anwander
Hello
That is something which annoys me too.
I think the A160 should be dropped and a A160-2 should be introduced
instead which uses a CD4029, which can be switched between counting
up/down and also with a presettable reset position.
Florian
>> Martin
> Best wishes
> Dieter Doepfer
AW: AW: [Doepfer_a100] A-160 Clock Divider modification for Down-counting possible?
> Hello
> Florian
We are about to design a A-16?-? that will use a microcontroller instead of
a hard wired counter. That way different counting and reset types could be
programmed and selected by the user (e.g. counting up or down or up inverted
or down inverted or ... , immediate reset or reset at next clock pulse,
advance to next step at the falling or rising edge of the clock signal).
Best wishes
Dieter Doepfer
Re: AW: AW: [Doepfer_a100] A-160 Clock Divider modification for Down-counting possible?
2010-11-23 by Bakis Sirros
indeed, very interesting module!
[Doepfer_a100] group owner
www. parallel - worlds - music. com
www. myspace. com/ parallelworldsmusic
www. myspace. com/ interconnectedmusic
www. myspace. com/ memorygeist
www. DiN. org. uk
www. musicamaximamagnetica. com
www. vu-us. com
--- On Tue, 11/23/10, Florian Anwander <fanwander@mnet-online.de> wrote:
Subject: Re: AW: AW: [Doepfer_a100] A-160 Clock Divider modification for Down-counting possible?
Date: Tuesday, November 23, 2010, 11:18 AM
      Hello Dieter,
Aaah! Much better!
Florian
2010-11-23 by achtung_999
Will this also be able to do the uneven divisions I have been bothering the
list with earlier, Dieter??
If yes then this will be a very very nice new addition to the Doepfer
range!!
grtz
Ernst
On Tue, Nov 23, 2010 at 10:12 AM, <yahoo@doepfer.de> wrote:
> > Hello
> > Florian
> inverted
> Best wishes
> Dieter Doepfer
2010-11-23 by martin sörensen
i´m wishing for cv in
so that it can be used as a A/D converter
i´m currently using a modified A-152 T&H module as a 3bit A/D
(fun to use as color select on my spectra physics 168 argon/krypton ion-laser :)
/martin
  Sent: Tuesday, November 23, 2010 10:12 AM
  Subject: AW: AW: [Doepfer_a100] A-160 Clock Divider modification for Down-counting possible?
  > Hello
  > Florian
  Best wishes
  Dieter Doepfer
> bothering the list with earlier, Dieter??
As the module is still in the design state I cannot give details. But as
it's microcontroller based it should be no problem to include different
counting/dividing types. The main problem is the operation (i.e. how to set
the dividing type and how to tell the user which type is chosen). An LCD
with menu buttons would be a bit over the top and increase the price
unnecessarily. Jumpers inside only and looking to a table would be a bit
laborious. So we will have to find a compromise between price and
operability.
Best wishes
Dieter Doepfer
something like this http://www.alpha-products.com/cd_catalog/new_catalogs/switches/std/dip/rotary/dip%20rotary%20sw2.htm for selection would be great you both get many positions and feedback to the user.
and it´s easy to interface to a mcu
another way is to use a pot connected to an analog input on the mcu and give binary feedback with
led:s or hexadecimal feedback with a 7 segment display
my personal favorite is the one with the pot and four led:s for binary feedback
(then it´s easy to modify it for function selection via cv ;)
skip the lcd thing it´s only expensive
/martin
  Sent: Tuesday, November 23, 2010 4:21 PM
  operability.
  Best wishes
  Dieter Doepfer
is it possible to incorporate "gray code"?
http://en.wikipedia.org/wiki/Gray_code
/martin
  operability.
  Best wishes
  Dieter Doepfer
