Yes, thanks for the info! I'll send it back for repair then.
Vesa
> > Hi y'all,
> > I have an issue with my A-147 VC-LFO -- The manual promises a
> > range of 0.01Hz - 50Hz.
> > Using the manual frequency control, I get frequencies in audio
> > range and beyond, from bass (100 Hz or so) to way above audio. No
> > sub-audio levels anywhere.
> > Can I adjust the range somewhere? Or should I send it back?
> > Thanks
> > Vesa
> That's totally strange as the max. frequency of the A-147 is usually around
> 200Hz. Maybe the LFO capacitor is defective (improbable) or one of the
> solder pins of the capacitor is loose (maybe cold solder joint). I'd
> recommend to return the module to the dealer or representative where you
> purchased the module for repair.
> Best wishes
> Dieter Doepfer
