Hi Zameer
Very similar to using the VC LFO for clocking the A155 sequencer
to get variable step length, but it would be "quantized", and easily
sync'ed to midi as well.
Joe
--- In Doepfer_a100@y..., "flamey101" <flame101@p...> wrote:
> This sounds like a good idea indeed, but, what's the difference in
> use between using a VC-LFO and the modded A163. I don't really
> geddit, but I don't have any fequency divders to check it out also..
> Greetings, Zameer
> --- In Doepfer_a100@y..., "Joe Buechler" <buechlerjoe@t...> wrote:
> > Thanks Peter. Ya, that's what I was planning to do, put the A129/3
> > next to one of my A138a mixers.
> > I have a question about the A163 VC Divider, one of the other
> modules
> > I'm considering. The User's Guide says that to obtain a DC coupled
> > output, the module can be modified by adding a jumper to short out
> the
> > cap C7. I'd like to use the A163 as a VC clock divider. What would
> I
> > be giving up if I jumper the capacitor?
> > Joe
> > --- In Doepfer_a100@y..., "(i think you can figure that out)"
> > <petergrenader@h...> wrote:
> > > The A129/3 IS AN EXTEMELY USEFUL MODULE!!!!!
> > > It allows for full processing of control voltages. What I
> suggest
> > you
> > > do however is (if you have one, if not this also recommended for
> the
> > > A129/3) is place a A138a cv mixer next to it, so you can easily
> mix
> > the
> > > prcoessed CVs as well.
> > > I don't own an A129/3. I ave built two processors that do the
> same
> > > thing -and- i own two Blacet mixer/processors that to this plus
> > mixing
> > > and I use them continually.
> > > Peter
> > > --- In Doepfer_a100@y..., unknown freak <ospengler@r...> wrote:
> > > > This is a really idiosyncratic question.
> > > > That said, I use my A129/3 a LOT.
> > > > > -----Original Message-----
> > > > > From: Joe Buechler [mailto:buechlerjoe@t...]
> > > > > Sent: Wednesday, September 25, 2002 10:56 AM
> > > > > To: Doepfer_a100@y...
> > > > > Subject: [Doepfer_a100] Suggestions for what to do with 24HP
> > > > > (or maybe 32)
> > > > > If I replace my A190/A191 with an MCV24, I'll have 24HP of
> space
> > > > > suddenly available. I could maybe extend that to 32HP if I
> lose
> > the
> > > > > A115 audio divider, which I don't use very often.
> > > > > Anyone have any good suggestions on how I might use this
> space?
> > > > > I'm considering the VC mixer (maybe with the morphing
> > controller).
> > > > > Another possibility is the A129/3 attenuator/offset module
> which
> > > > > might be really useful. I generally use a mixer and CV
source
> > for
> > > > > attenuation and offset, which would be free'd up.
> > > > > Maybe just an assortment of miscellaneous 8HP modules - I'm
> > somewhat
> > > > > interested in the freq shifter, the logic module, maybe the
> > analog
> > > > > version of the ribbon controller module instead of getting
> the
> > midi
> > > > > version.
> > > > > Comments? Suggestions?
> > > > > Joe
> > > > > ------------------------ Yahoo! Groups Sponsor
> > > > > ---------------------~--> Sell a Home with Ease!
> > > > > http://us.click.yahoo.com/SrPZMC/kTmEAA/MVfIAA> /QnLolB/TM
> > > > > To unsubscribe from this group, send an email to:
> > > > > doepfer_a100-unsubscribe@y...
> > > > > Your use of Yahoo! Groups is subject to
> > > > > http://docs.yahoo.com/info/terms/
