Doepfer
Dark Time additional Combi Modes
2012-12-31 by karelvanbezooijen
Hello,
I installed firmware version v1.2 today and noticed this when using the additional Combi Modes:
When using Mode 1 (which is the 'standard mode' i.e. lower row is gate length) row 1 is dependent to row 2. I mean step 9 always controlling step 1 and so on.
This is different is Mode 2 (lower row is velocity)
Example:
Row 1 = step 1 to 8
Row 2 = step 9
In Mode 2 I can control the entire Row 1 with just the knob of step 9 which is great. (esp. when velocity is controlling Cutoff)
In Mode 1 this is not possible (any more).
In this example step 9 is controlling the gate length of step 1 only.
I don't know if this has been programmed this way deliberately of course but personally I would like that Mode 1 is acting the same way as Mode 2.
Modes 4 (volume) and 6 (pitch) work the same as Mode 2 BTW.
Regards Karel
(BTW Dieter, I send you an email concerning the COTK ratchet sequencer some time ago. I found out that the setup can even be more simple as I thought. I use an A-138a mixer to mix the gates now which works great)
AW: [Doepfer_a100] Dark Time additional Combi Modes
2013-01-07 by yahoo@doepfer.de
Karel,
I'll send a copy of this email to Christian Assall (software@doepfer.de). He
programmed the new firmware and knows details. Please address questions that
relate to the Dark Time firmware directly to him.
Best wishes
Dieter Doepfer
> [mailto:Doepfer_a100@yahoogroups.com]Im Auftrag von karelvanbezooijen
> Gesendet: Montag, 31. Dezember 2012 12:23
> Betreff: [Doepfer_a100] Dark Time additional Combi Modes
> Hello,
> Example:
> Row 1 = step 1 to 8
> Row 2 = step 9
> way as Mode 2.
> Regards Karel
