Broken A-152
2013-03-12 by Dennis Verschoor
My a-152 only works in the last 4 steps. It doesnt goes to,the first ones at all. Maybe i should try and replace ome of the ic's? Cheers, Dennis -- Music at: http://www.mono-poly.nl [Non-text portions of this message have been removed]
2013-03-12 by yahoo@doepfer.de
> My a-152 only works in the last 4 steps. > It doesnt goes to,the first ones at all. > Maybe i should try and replace ome of the ic's? > > Cheers, > > Dennis Maybe the processor is defective (one address line not working) but that's only a guess. You may replace the processor but I cannot guarantee that this will solve the problem. Even if one of the DG408 multiplexers has a short circuit the same symptom would occur. I'd recommend to send in the module for repair. Best wishes Dieter Doepfer
Dear members, here are some A-100 news: The small version of the multiple A-180 is available in April 2013 (2 HP only, name: A-180-2) The A-130 (linear VCA) is now delivered with a precision VCA circuit (SSM2164) instead of the CA3080. The new A-130 is DC-coupled. The A-131 (exponential VCA) is now delivered also with an improved VCA circuit (high end THAT VCA circuit instead of the CA3080). The new A-131 is DC-coupled. The A-135 will be available from about May 2013 in a revised version with DC coupling of the signals and single outputs, i.e. it can be used also as 4 separate linear VCAs with manual gain, CV in with attenuator and signal in with attenuator. Because of the DC coupling it can be used also for modulation signal processing (i.e. voltage controlled mixing of control signals). The module A-171-2 (licensed copy of the Serge/CGS VCS) will be available about end of April or early in May 2013. We will show the prototype of the new version of the A-190-5 Polyphonic USB/Midi-to-CV/Gate Interface (with LCD) and the A-190-8 USB/Midi-to-Sync Interface at the Musikmesse in Frankfurt. These modules will be available about summer 2013. We will hopefully also show the "large" version of the trigger sequencer A-157/miniature Schaltwerk (8 rows with 16 steps each). The 8x16 button/LED board is ready but I cannot guarantee that the controller board will be also ready for the Musikmesse. That's it for now .... Best wishes Dieter Doepfer
2013-03-12 by ienni23
> We will show the prototype of the new version of the A-190-8 USB/Midi-to-Sync > Interface at the Musikmesse in Frankfurt. These modules will be available > about summer 2013. YAAAY!!!! this particular one is great news, and exactly what i've been needing and didn't even realize!! can't wait! :-)
2013-03-12 by thomas_escure
That's very good news ! Thank you especially for the improved A-130, A-131 and A-135. Also the A-171-2 is going to be great, though I find the graphics to be a little confusing. Are the "curves" pictures really necessary ? I think there's already a lot of info on little panel space... Of course it's a personal preference. Thomas --- In Doepfer_a100@yahoogroups.com, <yahoo@...> wrote:
> > Dear members, > > here are some A-100 news: > > The small version of the multiple A-180 is available in April 2013 (2 HP > only, name: A-180-2) > > The A-130 (linear VCA) is now delivered with a precision VCA circuit > (SSM2164) instead of the CA3080. The new A-130 is DC-coupled. > > The A-131 (exponential VCA) is now delivered also with an improved VCA > circuit (high end THAT VCA circuit instead of the CA3080). The new A-131 is > DC-coupled. > > The A-135 will be available from about May 2013 in a revised version with DC > coupling of the signals and single outputs, i.e. it can be used also as 4 > separate linear VCAs with manual gain, CV in with attenuator and signal in > with attenuator. Because of the DC coupling it can be used also for > modulation signal processing (i.e. voltage controlled mixing of control > signals). > > The module A-171-2 (licensed copy of the Serge/CGS VCS) will be available > about end of April or early in May 2013. > > We will show the prototype of the new version of the A-190-5 Polyphonic > USB/Midi-to-CV/Gate Interface (with LCD) and the A-190-8 USB/Midi-to-Sync > Interface at the Musikmesse in Frankfurt. These modules will be available > about summer 2013. We will hopefully also show the "large" version of the > trigger sequencer A-157/miniature Schaltwerk (8 rows with 16 steps each). > The 8x16 button/LED board is ready but I cannot guarantee that the > controller board will be also ready for the Musikmesse. > > That's it for now .... > > > Best wishes > Dieter Doepfer >
2013-03-13 by yahoo@doepfer.de
> That's very good news ! > Thank you especially for the improved A-130, A-131 and A-135. > Also the A-171-2 is going to be great, though I find the graphics > to be a little confusing. Are the "curves" pictures really necessary ? > I think there's already a lot of info on little panel space... > Of course it's a personal preference. > > Thomas From my point of view the "curves" pictures explain the behaviour much better than "-5" and "+5". Customers tend against r.t.f.m. :-) And then it's useful to have such additional information on the front panel without looking at the manual. Best wishes Dieter Doepfer
2013-03-13 by thomas_escure
--- In Doepfer_a100@yahoogroups.com, <yahoo@...> wrote: > > > That's very good news ! > > Thank you especially for the improved A-130, A-131 and A-135. > > Also the A-171-2 is going to be great, though I find the graphics > > to be a little confusing. Are the "curves" pictures really necessary ? > > I think there's already a lot of info on little panel space... > > Of course it's a personal preference. > > > > Thomas > > From my point of view the "curves" pictures explain the behaviour much > better than "-5" and "+5". Customers tend against r.t.f.m. :-) And then it's > useful to have such additional information on the front panel without > looking at the manual. > > Best wishes > Dieter Doepfer > OK, you win ! I LOVE reading manuals (and I like yours very much) but I know some people do not... One more question : in exp. mode, do the "CV up" and "CV down" pots control the slew shape even if there is no control voltage at the "CV up" and "CV down" inputs ? Thomas
> One more question : in exp. mode, do the "CV up" and "CV down" > pots control the slew shape even if there is no control voltage > at the "CV up" and "CV down" inputs ? Yes. But unfortunately it also has some influence to the frequency in LFO mode (i.e. when you change the shapes also the frequency changes). In slew or envelope mode that's not a real problem, but it's not possible to change only the shape of the LFO without changing the frequency a bit. Also the V/Oct input is not really V/Oct. We will change the label on the front panel probably to "exp.CV". Best wishes Dieter Doepfer
--- In Doepfer_a100@yahoogroups.com, <yahoo@...> wrote: > > > One more question : in exp. mode, do the "CV up" and "CV down" > > pots control the slew shape even if there is no control voltage > > at the "CV up" and "CV down" inputs ? > > Yes. But unfortunately it also has some influence to the frequency in LFO > mode (i.e. when you change the shapes also the frequency changes). In slew > or envelope mode that's not a real problem, but it's not possible to change > only the shape of the LFO without changing the frequency a bit. > > Also the V/Oct input is not really V/Oct. We will change the label on the > front panel probably to "exp.CV". > > Best wishes > Dieter Doepfer > Thank you for the detailed explanation. Since this "imperfection" is clearly stated I'm sure nobody will complain. I think people will agree if I say that analogue gear imperfections are part of its charms. Thomas
2013-03-13 by Bakis Sirros
great news about the improvement of the audio Quality of the A130/131 VCA modules! well done Dieter! also, can't wait for the A-157 Trigger Sequencer (mini-Schaltwerk) modules! regarding the Volt/Oct input of the A171-2 (Serge) Slope module, as far as i know, the Dual Transient Generator (or Dual Universal Slope Generator, its the same design) track well for about 3 octaves. but, of course, they are not temperature compensated. so, as the A171-2 is a serge design, the slope module should also track ok for about 3 octaves. if this is the case, maybe you should leave the Volt/Oct input named as such...? thanks, Bakis. ________________________________
From: "yahoo@doepfer.de" <yahoo@doepfer.de> To: Doepfer_a100@yahoogroups.com Sent: Tuesday, March 12, 2013 5:07 PM Subject: [Doepfer_a100] Some A-100 News Dear members, here are some A-100 news: The small version of the multiple A-180 is available in April 2013 (2 HP only, name: A-180-2) The A-130 (linear VCA) is now delivered with a precision VCA circuit (SSM2164) instead of the CA3080. The new A-130 is DC-coupled. The A-131 (exponential VCA) is now delivered also with an improved VCA circuit (high end THAT VCA circuit instead of the CA3080). The new A-131 is DC-coupled. The A-135 will be available from about May 2013 in a revised version with DC coupling of the signals and single outputs, i.e. it can be used also as 4 separate linear VCAs with manual gain, CV in with attenuator and signal in with attenuator. Because of the DC coupling it can be used also for modulation signal processing (i.e. voltage controlled mixing of control signals). The module A-171-2 (licensed copy of the Serge/CGS VCS) will be available about end of April or early in May 2013. We will show the prototype of the new version of the A-190-5 Polyphonic USB/Midi-to-CV/Gate Interface (with LCD) and the A-190-8 USB/Midi-to-Sync Interface at the Musikmesse in Frankfurt. These modules will be available about summer 2013. We will hopefully also show the "large" version of the trigger sequencer A-157/miniature Schaltwerk (8 rows with 16 steps each). The 8x16 button/LED board is ready but I cannot guarantee that the controller board will be also ready for the Musikmesse. That's it for now .... Best wishes Dieter Doepfer [Non-text portions of this message have been removed]
2013-03-13 by Peter Sedin
where is these pictures? 2013/3/12 thomas_escure <thomas_escure@yahoo.fr> > ** > > > That's very good news ! > Thank you especially for the improved A-130, A-131 and A-135. > Also the A-171-2 is going to be great, though I find the graphics to be a > little confusing. Are the "curves" pictures really necessary ? > I think there's already a lot of info on little panel space... > Of course it's a personal preference. > > Thomas > > > --- In Doepfer_a100@yahoogroups.com, <yahoo@...> wrote: > > > > Dear members, > > > > here are some A-100 news: > > > > The small version of the multiple A-180 is available in April 2013 (2 HP > > only, name: A-180-2) > > > > The A-130 (linear VCA) is now delivered with a precision VCA circuit > > (SSM2164) instead of the CA3080. The new A-130 is DC-coupled. > > > > The A-131 (exponential VCA) is now delivered also with an improved VCA > > circuit (high end THAT VCA circuit instead of the CA3080). The new A-131 > is > > DC-coupled. > > > > The A-135 will be available from about May 2013 in a revised version > with DC > > coupling of the signals and single outputs, i.e. it can be used also as 4 > > separate linear VCAs with manual gain, CV in with attenuator and signal > in > > with attenuator. Because of the DC coupling it can be used also for > > modulation signal processing (i.e. voltage controlled mixing of control > > signals). > > > > The module A-171-2 (licensed copy of the Serge/CGS VCS) will be available > > about end of April or early in May 2013. > > > > We will show the prototype of the new version of the A-190-5 Polyphonic > > USB/Midi-to-CV/Gate Interface (with LCD) and the A-190-8 USB/Midi-to-Sync > > Interface at the Musikmesse in Frankfurt. These modules will be available > > about summer 2013. We will hopefully also show the "large" version of the > > trigger sequencer A-157/miniature Schaltwerk (8 rows with 16 steps each). > > The 8x16 button/LED board is ready but I cannot guarantee that the > > controller board will be also ready for the Musikmesse. > > > > That's it for now .... > > > > > > Best wishes > > Dieter Doepfer > > > > > -- Mvh Peter H.K Sedin [Non-text portions of this message have been removed]
2013-03-14 by Bakis Sirros
http://www.doepfer.de/a1712.htm Bakis ________________________________
From: Peter Sedin <peterhksedin@gmail.com> To: Doepfer_a100@yahoogroups.com Sent: Thursday, March 14, 2013 1:17 AM Subject: Re: [Doepfer_a100] Re: Some A-100 News where is these pictures? 2013/3/12 thomas_escure <thomas_escure@yahoo.fr> > ** > > > That's very good news ! > Thank you especially for the improved A-130, A-131 and A-135. > Also the A-171-2 is going to be great, though I find the graphics to be a > little confusing. Are the "curves" pictures really necessary ? > I think there's already a lot of info on little panel space... > Of course it's a personal preference. > > Thomas > > > --- In Doepfer_a100@yahoogroups.com, <yahoo@...> wrote: > > > > Dear members, > > > > here are some A-100 news: > > > > The small version of the multiple A-180 is available in April 2013 (2 HP > > only, name: A-180-2) > > > > The A-130 (linear VCA) is now delivered with a precision VCA circuit > > (SSM2164) instead of the CA3080. The new A-130 is DC-coupled. > > > > The A-131 (exponential VCA) is now delivered also with an improved VCA > > circuit (high end THAT VCA circuit instead of the CA3080). The new A-131 > is > > DC-coupled. > > > > The A-135 will be available from about May 2013 in a revised version > with DC > > coupling of the signals and single outputs, i.e. it can be used also as 4 > > separate linear VCAs with manual gain, CV in with attenuator and signal > in > > with attenuator. Because of the DC coupling it can be used also for > > modulation signal processing (i.e. voltage controlled mixing of control > > signals). > > > > The module A-171-2 (licensed copy of the Serge/CGS VCS) will be available > > about end of April or early in May 2013. > > > > We will show the prototype of the new version of the A-190-5 Polyphonic > > USB/Midi-to-CV/Gate Interface (with LCD) and the A-190-8 USB/Midi-to-Sync > > Interface at the Musikmesse in Frankfurt. These modules will be available > > about summer 2013. We will hopefully also show the "large" version of the > > trigger sequencer A-157/miniature Schaltwerk (8 rows with 16 steps each). > > The 8x16 button/LED board is ready but I cannot guarantee that the > > controller board will be also ready for the Musikmesse. > > > > That's it for now .... > > > > > > Best wishes > > Dieter Doepfer > > > > > -- Mvh Peter H.K Sedin [Non-text portions of this message have been removed] ------------------------------------ Yahoo! Groups Links [Non-text portions of this message have been removed]
2013-03-15 by david.salter@thomsonreuters.com
Hi Dieter, Not sure how close to the CGS design this is re: power but any thoughts on if I could run it on a +/-15V system? Thanks David
From: Doepfer_a100@yahoogroups.com [mailto:Doepfer_a100@yahoogroups.com] On Behalf Of yahoo@doepfer.de Sent: 13 March 2013 15:19 To: Doepfer_a100@yahoogroups.com Subject: AW: [Doepfer_a100] Re: Some A-100 News > One more question : in exp. mode, do the "CV up" and "CV down" > pots control the slew shape even if there is no control voltage > at the "CV up" and "CV down" inputs ? Yes. But unfortunately it also has some influence to the frequency in LFO mode (i.e. when you change the shapes also the frequency changes). In slew or envelope mode that's not a real problem, but it's not possible to change only the shape of the LFO without changing the frequency a bit. Also the V/Oct input is not really V/Oct. We will change the label on the front panel probably to "exp.CV". Best wishes Dieter Doepfer This email was sent to you by Thomson Reuters, the global news and information company. Any views expressed in this message are those of the individual sender, except where the sender specifically states them to be the views of Thomson Reuters. [Non-text portions of this message have been removed]
2013-03-15 by yahoo@doepfer.de
> Hi Dieter, > > Not sure how close to the CGS design this is re: power but any > thoughts on if I could run it on a +/-15V system? > > Thanks > > David The main circuit is identical to the CGS. There are only some minor changes that do not affect the main circuitry. I think it will run with +/-15V. But I have no 15V supply available to try it out. Best wishes Dieter Doepfer
Thank you Dieter Rgds David
From: Doepfer_a100@yahoogroups.com [mailto:Doepfer_a100@yahoogroups.com] On Behalf Of yahoo@doepfer.de Sent: 15 March 2013 15:38 To: Doepfer_a100@yahoogroups.com Subject: AW: [Doepfer_a100] Re: Some A-100 News > Hi Dieter, > > Not sure how close to the CGS design this is re: power but any > thoughts on if I could run it on a +/-15V system? > > Thanks > > David The main circuit is identical to the CGS. There are only some minor changes that do not affect the main circuitry. I think it will run with +/-15V. But I have no 15V supply available to try it out. Best wishes Dieter Doepfer This email was sent to you by Thomson Reuters, the global news and information company. Any views expressed in this message are those of the individual sender, except where the sender specifically states them to be the views of Thomson Reuters. [Non-text portions of this message have been removed]
