Doepfer
Re: CV Bus question
Re: CV Bus question
2015-05-08 by Mark Koehler
I guess I don’t understand why it’s so useful when you have only ONE bus and would have little control over which modules are sources for the bus. I used to use it when I was mostly using MIDI for Gate and Pitch. When I started using all sorts of other sources and multiple cases, it fell by the wayside. I guess the A-185 solves some of those problems. It might be a bit blasphemous around here but I find Make Noise’s bus solution a bit better. I kind of wish someone would implement a similar feature using 3u modules. I know a vertical arrangement of a bus doesn’t match too well with a horizontal arrangement of modules but it’s better to me than buying a new case (which they don’t even sell separate from their systems).
Mark
Atlanta GA
