Doepfer
AW: [Doepfer_a100] Wire lenght between A-176 potentiometers and PCB
2015-08-03 by yahoo@doepfer.de
> Hello,
> I'd really like to change the ergonomics of the A-176 so that it would better suit my needs.
> I'm thinking of moving the potentiometers away from the faceplate and PCB and attaching them to another, separated faceplate.
> Could someone suggest a maximum wire length between the A-176 pots and the PCB ?
> Thomas
It's impossible to specify a certain max. length. The longer the cable the more noise and interference the cable will pick up and
forward to the output. But if you use shielded cables a few meters should be possible. With unshielded cables at least 50 cm should
work.
Best wishes
Dieter Doepfer
Re: AW: [Doepfer_a100] Wire lenght between A-176 potentiometers and PCB
2015-08-03 by thomas_escure@yahoo.fr
Hello Dieter,
Thank you very much for your answer.
I think I won't need the wires to exceed 50 cm, but I'll investigate further about shielded wires, just in case.
That"s one of the aspects that I deeply appreciate with modular systems : the more you spend time using it, the more you learn interesting info about music, electronics, mechanics...
Especially when people are so inclined to answer your questions !
Have a nice day,
Best regards,
Thomas
AW: AW: [Doepfer_a100] Wire lenght between A-176 potentiometers and PCB
> One more question :
> If I ever use shielded wire, should I connect one end of the shield to the A-176 PCB, for grounding ?
Yes, and you may use it at the same time for the GND of the potentiometer. I.e. you need a shielded cable with only two wires +
shield.
Best wishes
Dieter Doepfer
