Doepfer DIY questions
2016-01-27 by funster21wi@yahoo.com
Hey guys,
So I've been putting together one of these Doepfer DIY kits, and have finally gotten to the point where I can test it. I basically followed the example drawing in the back of the manual. I have a couple of questions, if anyone can offer any help I'd greatly appreciate it!
1. When I first hooked up the audio out I got a lot of really horrible buzz, after poking around for quite a while I noticed that if I shorted the other side of the stereo 7mm jack to ground it seemed to get rid of the noise, but I had to turn my amp way up in order to hear it! Is this how I should have done this, or am I missing something altogether?
2. In general, how, if at all, should the metal face plate I'm using be grounded? At the moment it is not, I don't seem to be getting any additional buzz from touching the case.
3. When should the ADSR LED light up? For the longest time I hadn't seen it light up at all, but after some prolonged screwing around it would start to pulse, but I wasn't really sure what had happened to make that start working.
Again, any info at all would be appreciated,
Thanks!
