Run/stop and clock to A-157; A-166 with two inputs
2016-04-07 by Zoë Blade
Hi! Someone's asked me about hooking up a module with clock and run/stop out to the A-157. My thinking is that as the A-157 doesn't have a run/stop in, you'd need to use something like the A-166 to logically AND together the clock and run/stop signals, then feed that into the A-157's clock input, press start on the A-157, then press start on the other module. Does this sound right? Is it possible to logically AND only two inputs with the A-166? Will pressing start on the A-157 cause it to politely wait to get a clock signal, and then play the first row with the first pulse it gets? Thanks! Zoë.
