Doepfer
A-190-3 Velocity
A-190-3 Velocity
2017-05-12 by Neil Kagan
Hi to you all,
I’m trying rather unsuccessfully to turn off velocity on CV 3 and 4 on the A-190-3. I’ve sent program changes from Logic but nothing seems to work. Has anyone on here had success and if so how? I have both Logic and Ableton.
Neil
Re: [Doepfer_a100] A-190-3 Velocity
2017-05-12 by Diego Ragnini
Hi Neil,
I don’t know that much about this interface, I simply use it without particular exigences or issues and I am not sure to can grasp what is the application in the background of your request.
By the way, I am afraid that there’s no way to turn off velocity from CV3 jack (the only one concerned by velocity). It seems that this jack permanently outputs the velocity voltage (any time a note-on signal occurs) and cannot be the destination of further assignments. You can always un-plug the cable from that jack.
Best,
Diego
> Il giorno 12 mag 2017, alle ore 16:24, Neil Kagan nkagan@mac.com [Doepfer_a100] <Doepfer_a100@yahoogroups.com> ha scritto:
> Hi to you all,
> Thanks,
> Neil
You can prevent it outputting velocity CC via a program change. However it doesn't seem to be working for me!
> On 12 May 2017, at 17:46, Diego Ragnini diegora@free.fr [Doepfer_a100] <Doepfer_a100@yahoogroups.com> wrote:
> Hi Neil,
> Best,
> Diego
>> Hi to you all,
>> Thanks,
>> Neil
AW: [Doepfer_a100] A-190-3 Velocity
2017-05-15 by yahoo@doepfer.de
Pay attention to the note the A-190-2 user's manual on page 8:
"Important  note:  Pay  attention  that  some  manufacturers
count  the  Midi  program  change  numbers  from  1....128,
others from 0...127. In this manual the counting 1...128 is
used.  Please  look  into  the  user's  manual  of  your  Midi
device which type of counting is used. If the counting type
0...127  is  used  one  has  to  subtract  1  from  the  program
change  numbers  in  the  table  above.  For  some  devices
(especially  software  sequencers)  the  type  of  program
change  numbering  can  be  selected.  In  this  case  you
should use the 1...128 range to agree with the numbers in
the table above."
Maybe this the reason for the problem.
Best wishes
Dieter Doepfer
> Von: Doepfer_a100@yahoogroups.com [mailto:Doepfer_a100@yahoogroups.com]
> Gesendet: Freitag, 12. Mai 2017 16:25
> Betreff: [Doepfer_a100] A-190-3 Velocity
> Hi to you all,
> Thanks,
> Neil
> Posted by: Neil Kagan <nkagan@mac.com>
> Yahoo Groups Links
Re: AW: [Doepfer_a100] A-190-3 Velocity
2017-05-15 by Neil Kagan
Hi Dieter,
I've tried both formats. Neither is working.
Neil
> On 15 May 2017, at 09:22, yahoo@doepfer.de [Doepfer_a100] <Doepfer_a100@yahoogroups.com> wrote:
> the table above."
> Best wishes
> Dieter Doepfer
>> Hi to you all,
>> Thanks,
>> Neil
>> Yahoo Groups Links
> Yahoo Groups Links
AW: AW: [Doepfer_a100] A-190-3 Velocity
That's strange as it would be the first A-190-3 where this function is not
working. If you are sure that it's not a problem of the Midi transmitter
return the module for checking. But I cannot imagine that all Midi functions
of the module are working except the velocity cancelling of CV3/4. You may
also contact Christian Assall (software@doepfer.de). Maybe he has an idea
for the behaviour.
Best wishes
Dieter Doepfer
> Gesendet: Montag, 15. Mai 2017 10:42
> Betreff: Re: AW: [Doepfer_a100] A-190-3 Velocity
> Hi Dieter,
> Neil
> Sent from my iPhone
> > the table above."
> > Best wishes
> > Dieter Doepfer
> >> Hi to you all,
> >> Thanks,
> >> Neil
> >> Yahoo Groups Links
> > Yahoo Groups Links
> Yahoo Groups Links
Re: AW: AW: [Doepfer_a100] A-190-3 Velocity
Thanks Dieter I'll email him.
Neil
> On 15 May 2017, at 10:25, yahoo@doepfer.de [Doepfer_a100] <Doepfer_a100@yahoogroups.com> wrote:
> for the behaviour.
> Best wishes
> Dieter Doepfer
>> Hi Dieter,
>> Neil
>> Sent from my iPhone
>>> the table above."
>>> Best wishes
>>> Dieter Doepfer
>>>> Hi to you all,
>>>> Thanks,
>>>> Neil
>>>> Yahoo Groups Links
>>> Yahoo Groups Links
>> Yahoo Groups Links
> Yahoo Groups Links
