> Von: Doepfer_a100@yahoogroups.com [mailto:Doepfer_a100@yahoogroups.com]
> Gesendet: Montag, 6. August 2018 15:17
> Betreff: Re: [Doepfer_a100] Problem with A-190-4
> The interplay among the korg SQ-1, the A-190-4 and eventually a
> PC is not clear to me
> Can the korg SQ-1 sequencer actually send MIDI via USB to the PC
> and so to the A-190-4?
> Maybe you can forward precisions of your hw configuration
> I had a similar problem long ago interfacing OSX 10.6.8 with the
> A-190-4, so the master keyboard actually sent messages but the
> A-190-4 wasn’t detected by the MIDI Audio setup sometimes (have
> to keep the A-190-4 powered on before powering on the Mac). But
> if your DAW sends clock to A-190-4 (but not MIDI notes!?) then
> it’s not the case..
> Diego
> > Il giorno 06 ago 2018, alle ore 13:52, yahoo@doepfer.de
> [Doepfer_a100] <Doepfer_a100@yahoogroups.com> ha scritto:
> > Hello,
> > if the clock is working the midi connection is working in
> principle. Please
> > check if the midi channel and note range of the transmitter
> corresponds to
> > the settings of the A-190-4. And make sure that the required
> note messages
> > are really sent by the midi transmitter.
> > Best wishes
> > Dieter Doepfer
> >> Gesendet: Montag, 6. August 2018 13:01
> >> Betreff: [Doepfer_a100] Problem with A-190-4
> >> Hi All,
> >> I am having a problem with my A-190-4 today and I'm hoping
> >> someone may be able to assist. My A-190 does not appear to be
> >> processing CV or Gate signal. I have tried sending signal from a
> >> midi keyboard and from a korg SQ-1 sequencer but no CV or gate
> >> signal is produced. I do get a clock signal when the sequencer
> >> is attached. I have tried to different midi cables also just to
> >> rule out a bad cable issue.
> >> I can scroll through the menu on the A-190 so the module does not
> >> appear to be frozen.
> >> All connections are made using the midi in port, not USB.
> >> Would anyone have advice on how to troubleshoot this problem?
> >> Thanks,
> >> Colum
> > Yahoo Groups Links
> Posted by: Diego Ragnini <diegora@free.fr>
> Yahoo Groups Links
