Doepfer
A-199 Spring Reverb in a A-100 Mini Case. Good idea?
2018-12-17 by Alex
Hi all,
I am considering buying a A-199 Spring Reverb module and put it into a A-100 Mini Case. Of course, the Spring Tank would be outside of the box but I am worried about the hum noise considering what the manual says:
As the hum noise is mainly caused by the magnetic
field of the power supply transformer we recommend
the usage of the special A-100 power supply with ring
core transformer (A-100PSU2) instead of the standard
power supply (A-100NT12) for all A-100 systems that
include an A-199 module.
I don't know if the power supply version 3 is the right choice for it.
Here is a picture:
Thank you so much in advance.
Alex
AW: [Doepfer_a100] A-199 Spring Reverb in a A-100 Mini Case. Good idea?
2018-12-17 by yahoo@doepfer.de
Hello,
I don't see a problem as the A-100MC uses an external power supply
(transformer). You only have to pay attention that there is sufficient
distance between the supply and the reverb tank (and that there are no other
magnetic troublemakers near the reverb tank).
Best wishes
Dieter Doepfer
> Von: Doepfer_a100@yahoogroups.com [mailto:Doepfer_a100@yahoogroups.com]
> Gesendet: Montag, 17. Dezember 2018 13:01
> Betreff: [Doepfer_a100] A-199 Spring Reverb in a A-100 Mini Case. Good
> idea?
> Hi all,
> Here is a picture:
> https://drive.google.com/open?id=1IvfdOdd29-2JoFCG2OU0rsoJtNL52vgv
> Alex
Re: [Doepfer_a100] A-199 Spring Reverb in a A-100 Mini Case. Good idea?
2018-12-17 by Alex
Thank you so much Dieter. That's what I wanted to hear. Sold.
Cheers
El lun., 17 dic. 2018 a las 16:52, yahoo@doepfer.de [Doepfer_a100] (<Doepfer_a100@yahoogroups.com>) escribió:
Hello,
Best wishes
Dieter Doepfer
> idea?
> Hi all,
> Here is a picture:
> Alex
Yahoo Groups Links
<*> To visit your group on the web, go to:
http://groups.yahoo.com/group/Doepfer_a100/
<*> Your email settings:
Individual Email | Traditional
<*> To change settings online go to:
http://groups.yahoo.com/group/Doepfer_a100/join
(Yahoo! ID required)
<*> To change settings via email:
Doepfer_a100-digest@yahoogroups.com
Doepfer_a100-fullfeatured@yahoogroups.com
<*> To unsubscribe from this group, send an email to:
Doepfer_a100-unsubscribe@yahoogroups.com
<*> Your use of Yahoo Groups is subject to:
https://info.yahoo.com/legal/us/yahoo/utos/terms/
