Doepfer
A-152 question
A-152 question
2019-04-07 by exakoustidismiltiadis@hotmail.com
Hello again!
I am a happy owner of this fantastic and versatile module!
But I have some questions, maybe I have them due to my poor English.
I read in the manual, page 5
Only control voltages can be processed by the T&H unit due to the holding capacitors of the T&H circuits. The T&H section is not suitable for audio signals.
First of all I suppose that I can eject a slow LFO. If I am right, until how many Hz T&H section
can process?
Secondly, again in the manual, page 6.
JP8 top, JP7 away from the common T&H (factory setting) .
In this case the common input of the T&H unit 2b is connected to the common socket of the multiplexer unit 1b provided that no plug is inserted into the common input of the T&H unit 2b.
Provided that only control voltages can be processed by the T&H unit, if I inject an audio signal in Common
Switch input it will be transferred in the common T&H Input because of the normalization. This is illogical to
me. Maybe I misunderstand something, I am asking kindly of your help!
Best regards,
Miltos
AW: [Doepfer_a100] A-152 question
2019-04-08 by yahoo@doepfer.de
Hello,
you find my answers written inline.
Best regards
Dieter Doepfer
> Von: Doepfer_a100@yahoogroups.com [mailto:Doepfer_a100@yahoogroups.com]
> Gesendet: Sonntag, 7. April 2019 14:44
> Betreff: [Doepfer_a100] A-152 question
> Hello again!
> can process?
A slow or even fast LFO is no problem. The holding capacitors of the T&H are
22nF. The exact frequency is a bit hard to define because it depends upon
the "ON" resistance of the electronic switches which do not have an exact
value.
I suppose it will work at least up to a few hundred Hz.
If audio signals have to be processed by the switch section this
normalization should not be installed (or removed).
> Best regards,
> Miltos
Re: AW: [Doepfer_a100] A-152 question
2019-04-08 by exakoustidismiltiadis@hotmail.com
For one more time, thank you very much again Dieter! Everything now is crystal clear!
I suppose... :-)
Best Regards,
Miltos
