Fwd: AW: [Doepfer_a100] 3.5mm patchbay?(doepfer's answer)
2003-06-13 by Bakis Sirros
--- Dieter Doepfer <hardware@doepfer.de> wrote: > From: "Dieter Doepfer" <hardware@doepfer.de> > To: "Bakis Sirros" <synth_freak_2000@yahoo.com> > Subject: AW: [Doepfer_a100] 3.5mm patchbay? > Date: Fri, 13 Jun 2003 12:07:29 +0200 > > Please forward ...... > > > -----Urspr�ngliche Nachricht----- > > Von: dustin_l_mosley > [mailto:dustinmosley@hotmail.com] > > Gesendet: Donnerstag, 12. Juni 2003 22:29 > > An: Doepfer_a100@yahoogroups.com > > Betreff: [Doepfer_a100] 3.5mm patchbay? > > > > > > Hi, > > Does anyone know of a company that makes a > patchbay with > > mono 3.5mm connections on the front to help > integrate other > > pieces of gear to your a-100? I have a few A-181s > (the mult with > > the adapter from 1/4") but it's slow and a pain to > use with gear > > with connections on the back. Any ideas or > solutions? > > Thanks > > Dustin > > We have built such a patchbay for our own > applications (19" / 1HU / 2 x 20 > 3.5mm sockets front + rear), especially for > demonstration of > MAQ/Schaltwerk/Regelwerk during music fairs, > workshops and so on. We connect > the CV/Gate outputs of MAQ/Schaltwerk/Regelwerk at > the rear side and have > the signals then available at the front too to patch > them to the A-100 > system. We asked visitors of fairs/workshops if they > would be interested in > such a patchbay but found that there are not > sufficient inquiries. > > We could manufacture this patchbay if there are > sufficient orders. But the > device is not low cost. 80 jack sockets have to be > soldered to the pc board > and mounted to the 19" front panel. In small > quantities (~50) the price will > be around 150 Euro (80 jack sockets 1 Euro each + 5 > pc boards + 19"/1HU > front panel + charges for punching the holes, > lacquer of the front panel, > soldering, assembly and test). > > But as nobody was interested in this patchbay so far > - maybe because of the > price - we did not offer it. Alternatively we could > offer only the > stamped/laquered front panel without sockets and pcb > at a much lower price > (~ 20..25 Euro). In this case the customer will have > to assemble the jack > sockets himself. > > Best wishes > Dieter Doepfer > ===== synthfreak(parallel worlds) athens-greece [Doepfer_a100] group owner __________________________________ Do you Yahoo!? Yahoo! Calendar - Free online calendar with sync to Outlook(TM). http://calendar.yahoo.com
