Doepfer
about the COMB. FILTER MODULE...
2002-02-13 by synth_freak_2000
HI LIST,
some info on the subject from dieter:
bakis:  "do you think that it would make sense to make a new poll
about a comb. filter module??or it is similar to the phase shifter
module??"
dieter doepfer:  "There exists not only one "comb filter" module
type. A comb filter may be realized with phase shifters (i.e. phase
shift) or delay units (i.e. time shift) or even with several notch
filters in series. The main difference is the spacing between
the "holes" of the combs on the frequency axis. The effect resulting
from phase shifting is called phasing, the effect resulting from time
shifting is called flanging (earlier made with two tape recoders by
alternately slowing down the reels or flanges with the fingers). The
most versatile is the last solution with separate notch filter that
may be controlled by different CV sources (e.g. independent LFOs or
Shepard CVs or random or or or ...). In addition feedback can be used
(like filter feedback). Somewhere I have details of the difference
between phasing and flanging (pictures of the frequency distribution
of the "holes", as far as I remember the holes are equal spaced for
the flanger and logarithmic for the phaser). But as I'm very busy for
the fair I don't have the time to search the documents. Maybe someone
of the newsgroup knows detailes too (Florian ?). As far as I remember
it was in an issue of the Polyphony magazine (about 1983/84). By the
way a very interesting magazine for technical details of modular
synthesizers but they stopped it middle of the eighties. Maybe
someone has scanned the magazine."
...so...anyone??florian??
synthfreak
athens-greece
[doepfer_a100] group moderator
Re: [Doepfer_a100] about the COMB. FILTER MODULE...
2002-02-13 by Florian Anwander
Hi Bakis
> dieter doepfer:  "[...]Maybe someone
> of the newsgroup knows detailes too (Florian ?).[...]
The "comb filter" thing I already mentioned in the mail from 4th of
February. I wrote
"[...]by an allpass filter (which is used also for phaser) or by a delay.
Both do similar but technically not identical effects."
I thought this was very clever, since I had not to explain the difference
in detail ;-) ok, now you've got me...
The difference between the (analogue) phaser and the flanger in reality is
the technical way, how a signal delay is created.
The delay in the flanger is realized with some kind of signal storage,
which does not change the signal itself generally. The stored signal is
kept for a while and then played back. This is realized either with digital
storage or in older flangers and guitar efx with so called bucket bridge
delays.
The phase works also with a delay, but this time the delay is realized with
an so called allpass filter. An allpass filter is a circuit which does
not(!) filter. This sounds senseless as long as you think filtering is the
only thing that a filter does; but a filter does a lot more:
- it does a very(!) small delay (this is, what the phaser wants to use)
- and it shifts the phase of partial notes above the cutoff-frequency
  (yes an allpass filter has still something like a cutoff-frequency,
  though it does not cutoff anything). This phaseshift is originally
  not intended, but it is typical for all analogue filter designs.
As we already learned: A comb effect is generated by elimination of partial
tones, which happen when a delayed signal is mixed together with the non
delayed signal. Now you can imagine, that the phase shift of the partial
tones in  the allpass will cause, that other partials will be eliminated.
So far the technical background.
__Which__ special frequencies are eliminated and how this looks (linear or
logarithmic...) I do not remember. Sorry. I know there is a paper somewhere
deep in the big paper sink in my room ;-) but I cannot promise, that I will
find it. So I fear the answer won't be better than the one, you already
received by Dieter.
Florian
Florian Anwander                  |ConSol*  HP-Support
Tel.   +49.89.45841-133           |Consulting&Solutions Software GmbH
Fax    +49.89.45841-139           |Franziskanerstr. 38, D-81669 München
email: florian.anwander@consol.de |http://www.consol.de
Re: about the COMB. FILTER MODULE...
thanks florian!!
synthfreak
--- In Doepfer_a100@y..., Florian Anwander <Florian.Anwander@c...>
wrote:
> Hi Bakis
delay.
difference
reality is
storage,
signal is
digital
bridge
> delays.
realized with
does
is the
use)
frequency
frequency,
originally
partial
the non
partial
eliminated.
(linear or
somewhere
that I will
already
> received by Dieter.
> Florian
GmbH
München
> email: florian.anwander@c... |http://www.consol.de
