Re: a155 seq question
2005-03-10 by gargar1974
The trig outs output what you have in the clock in. What are you using in the input? So if you drive it with a square lfo, it will output a rising edge and then a falling edge. Maybe what you are trigggering reacts to both? I use it with the square wave from A-145 and send the trigger out to the A-140 and I dont have this problem. I think you'll like this module. I love it. /gustaf --- In Doepfer_a100@yahoogroups.com, "Paul Wagorn" <pwagorn@p...> wrote: > Ok, so I've only had this module for a short while, but I'm having a strange > issue that is more likely me not understanding something than a problem with > the module: > > On the cv out for each row, at each step it actually pulses twice for each > "note" in the sequence. I don't have a scope to verify exactly what it's > doing, but if I pluf the pre or post out into an oscillator, it plays each > step twice (and I'm not using a vca!), I assume it's outputting some sort of > square wave for some reason. Even when I advance the step manually, for > each step it goes "beep - beep" (again without any vca) > > Am I missing something basic here? I think I understand the theory of the > 155, and I've had lots of other analogue sequencers, and I've never seen
> this. > > Paul
