Doepfer
suggestion for alternative quantizing module
2005-11-02 by Anton Coops
Hi list,
Dividing an octave in 12 equal steps is fine, but what I would like
even more is a quantizing module that can divide an octave in 'n'
steps
n = 1: 1 step of 1200 cents
n = 2: 2 steps of 600 cents
n = 3: 3 x 400 cents etc. etc., maybe up to n = 25
note: a transpose-option (like in the a-156) should transpose in 'n-
ed' steps as well. Unusual sounds gauranteed!
Good idea or am I missing something? Has somebody allready built
a module that can do this?
greetings
Anton
Re: suggestion for alternative quantizing module
2005-11-03 by selfoscillate
hello anton,
i tried this with reaktor a few months/years ago,
and there is one problem with it.
the whole show sounds just "out of tune" when
the octave is divided in a range that doesn't fit
to the semitone scale. dividing an octave by 7 for
example will only give you wrong notes, but it won't give
you new sounds, just old sounds which are out of tune.
ok, maybe somebody wants that, but i can't imagine why.
only my 2 cents
best wishes
ingo
--- In Doepfer_a100@yahoogroups.com, "Anton Coops" <dubshot@x...>
wrote:
> Hi list,
> steps
> greetings
> Anton
hello florian,
thats a very good point.
maybe i was too straight with my reaktor-approach,
i haven't tried it with fm. thanks for the hint.
best wishes
ingo
--- In Doepfer_a100@yahoogroups.com, Florian Anwander
<Florian.Anwander@c...> wrote:
> Hi Ingo
> E.g. for controlled FM: tune the carrrier VCO with the original CV,
and
> a the modulator VCO with the stepped CV.
> Does very nice things.
> Florian
Re: [Doepfer_a100] Re: suggestion for alternative quantizing module
2005-11-03 by Florian Anwander
Hi Ingo
E.g. for controlled FM: tune the carrrier VCO with the original CV, and
Florian
2005-11-03 by achtung_999
I'm sorry Ingo.
Anton is going into microtonality here.
I personally think this kind of a quantizer would be cool.
Out of tune does not exist, not fitting with a certain tonality would
be a better description.
Ernst.
On 11/3/05, selfoscillate <synaptic_music@yahoo.com> wrote:
>  hello anton,
>  only my 2 cents
>  best wishes
>  ingo
>  wrote:
>  > Hi list,
>  > steps
>  > greetings
>  > Anton
>  SPONSORED LINKS
>  A100 Synthesizer Electronic payment
>  Electronic test equipment Guitar synthesizer Voice synthesizer
>  ________________________________
>  YAHOO! GROUPS LINKS
>  Visit your group "Doepfer_a100" on the web.
>  To unsubscribe from this group, send an email to:
>  Doepfer_a100-unsubscribe@yahoogroups.com
>  Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service.
2005-11-03 by Anton Coops
Hi Ingo,
Out of tune-ness does not only come from the scale you use, but
also from the timbre that you use in a given scale (and of course the
combinations of notes you play). It can take some time before you
find a good combination, but there are some tricks.
So in the module I suggest, for *each* value of 'n', or for each
scale, you have *specific* combinations of notes and timbres that
sound good or don't sound good.
One advantage of the approach I suggested would be that you can
more easily modulate in equally divided scales than in other unusual
or experimental scales. It's also basic, a bit like the freqency divider,
so that should increase the possibilities for mis-use :-)
Anton
On 3 Nov 2005, at 16:11, selfoscillate wrote:
> hello anton,
> only my 2 cents
> best wishes
> ingo
> wrote:
> > Hi list,
> > steps
> > greetings
> > Anton
2005-11-04 by selfoscillate
hello anton, ernst, florian,
all good points. thanks for making me understand.
best wishes
ingo
wrote:
> Hi Ingo,
unusual
divider,
> Anton
> > hello anton,
> > only my 2 cents
> > best wishes
> > ingo
> > --- In Doepfer_a100@yahoogroups.com, "Anton Coops" <dubshot@x>
> > wrote:
> > > Hi list,
like
in 'n'
> > > steps
in 'n-
built
> > > greetings
> > > Anton
> > Yahoo! Groups Links
Re: [Doepfer_a100] suggestion for alternative quantizing module
2005-11-04 by Anton Coops
Hi sfrules,
If you would like to know more about the use of scales and tunings
in electronic music you could start by checking out what William
Sethares has to say about this
http://eceserv0.ece.wisc.edu/~sethares/ttss.html
About software: if you want to experiment with tunings etc. you could
use samplers, synthesizers, and even my old vintage keys module
will do. Also there are some fine specialised programs like scala
http://www.xs4all.nl/~huygensf/scala/
But I don't want software because it gives me RSI!! :-))  I would like
to experiment with tunings using VC, but afaik such modules are not
on the market yet, but I'm not 100% sure.
Anton
On 4 Nov 2005, at 7:59, sfrules wrote:
> Hello,
> Perhaps you should explore Microtonal music.  Yahoo search even
> turned up a site for computer programs that will do it.
> For now check this out...
> http://www.microtonal.freeservers.com/
> sfrules
2005-11-05 by sfrules
Hail, Anton!
(This post is gonna be a hodge-podge.  Begging forgiveness in
advance.  You're not the only one with verbal diarrhea, Morbs.)
I read your post and was remembering a link someone had posted to a
microtonal site in the last year or so.   I waited for them to help
you.  Nothing.
It seems you were the one in the first place!
Your post is awesome!  I thirst for knowledge.  Maybe the right word
is lust.
I've read John Backus' book THE ACOUSTICAL FOUNDATIONS OF MUSIC
http://www.amazon.com/exec/obidos/tg/detail/-/0393090965/
qid=1131198835/sr=8-1/ref=sr_8_xs_ap_i1_xgl14/104-8390523-9984722?
v=glance&s=books&n=507846
and found it fascinating.  (If you haven't read it, you will too!)
Now I find I must absorb Sethares' book!
Knowing you may also have trod in these other footsteps as well, may
I recommend
Wendy Carlos' CD's, BEAUTY IN THE BEAST   and   TALES OF HEAVEN & HELL.
She uses microtonal to advantage.
I suppose it's obvious to you and everyone else that merely
attenuating keyboard voltage will give you octaves of any number of
steps you wish.  I recall reading somewhere that there are two other
mathematical divisions of an octave that create consonance -
something like 29 and 36 steps.  Do you know what those actual
divisions may be?   Thanking in advance.
If you've been around a while - and I think you have - you may recall
my supplication for a selective quantizer.  Without going into
detail, I'll just attach the jpg in the middle of this post.
Permit me to say that your quantizer suggestion goes even further and
would make an exciting module.  I don't know many Roger would sell -
we'd probably have to get a second mortgage on our first-born to buy
one.
Let me wrap this up with a bizarre, but true tale.
I poked deeply into Sethares' site and found a sound bite for Chapter
8 A BELL, A ROCK, A CRYSTAL: DUET FOR MORPHINE AND CYMBAL.
Let me set the stage.  I understand consonance and dissonance.  I
knew what to expect.
My home stereo connection is kaput.  I had to play it on my computer
with the volume cranked up.  I have a head cold.  My hearing is
f*cked up.  Everything sounds like it is resonating in a pipe the
wrong size.
So I started the bite.  Then our home phone started to ring with its
chintzy beeping of Grieg's Hall of the Mountain King.
All I can say is, Lay off the cattle prod, Morby!
sfrules
2005-11-05 by Anton Coops
Hey sfrules
Thanks for the support :-)
Be sure to get the second edition from 2005, it's improved.
> I recommend
Thanks, I will keep those in mind. She is also quoted by Sethares.
> steps you wish.
True, but this method is not allways what you want, especially the
user-friendliness, but also the possibilities. As far as I know it's
impossible e.g. to use the a-156 quantiser (12-tet) to divide an
octave in 5 equal steps. It seems you can only shrink the intervals,
but not increase them. But perhaps I'm missing a clever trick here?
Also the future Doepfer cv-keyboard might be handy.
I wouldn't know what you mean, as consonance is not just a matter
of division of the octave. But my guess is that you mean 19 instead
of 29.
oops, it's gone I think?
Greetings
Anton
To Anton quantizing module
2005-11-20 by sfrules
'Lo!
Found this on another group.
I'm sure if you haven't already been there, that
it's what you're looking for!
---> John Loffink
The Microtonal Synthesis Web Site
http://www.microtonal-synthesis.com
The Wavemakers Synthesizer Web Site
http://www.wavemakers-synth.com
sfrules
