Doepfer
comparing ring modulators
2005-11-15 by selfoscillate
hello,
yesterday i modded an a114 like suggested
by peter and tim. when testing the device
i compared it with other ringmodulators.
here is a short recording to show the
timbral differences and also the varying
loudness.
http://www.selfoscillate.de/a100files/ringmods-sequence.mp3
file size: 429 kb
all ring modulators use the same audio sources
(sinewaves from two a111, each vco's pitch is
controlled by it's own sequencer row).
1. a114 original
2. a114 tim's mod (c1 shorted)
3. a114 peter's mod (c2 shorted)
4. blacet klangwerk
5. cgs real ring modulator
best wishes
ingo
Re: comparing ring modulators
2005-11-15 by atuzzi
Hi Ingo,
thanks, great comparison
you should add a DSP style ring modulator too, just too see the
deviation from the "pure" mathematical creation (something like CSound
or MAX or the pick your flavour).
I must say the more dramatic is #3
And I don't understand the missing lows in the #5 (the mp3 compression ?)
thank you
at
--- In Doepfer_a100@yahoogroups.com, "selfoscillate"
<synaptic_music@y...> wrote:
> hello,
> loudness.
> file size: 429 kb
> 1. a114 original
> 4. blacet klangwerk
> best wishes
> ingo
2005-11-15 by ilanode
Hello Ingo, great that you were busy once more supplying us with
some samples. Very much appreciated, very helpful. Thanks! Ingo-not-
self-oscilating
> hello,
> loudness.
> file size: 429 kb
> 1. a114 original
> 4. blacet klangwerk
> best wishes
> ingo
hello antonio,
the missing lows in #5 are probably because the
cgs real ring is a passive device, the output
loudness is weak on this module.
i haven't amplified the module output to show
the differences in loudness.
dsp-based ring modulators are not really interesting
for me. i built lots of such stuff in reaktor but the
result was always much too clean, too digital-sounding.
best wishes
ingo
--- In Doepfer_a100@yahoogroups.com, "atuzzi" <antoniotuzzi@t...>
wrote:
> Hi Ingo,
CSound
compression ?)
> thank you
> at
> > hello,
> > loudness.
> > file size: 429 kb
> > 1. a114 original
> > 4. blacet klangwerk
> > best wishes
> > ingo
> hello antonio,
Just want to add that the RRM is known to load the VCOs and thus
affecting their performance. The results would be different if the
inputs of the RRM were buffered. One could add an Op Amp to each
input or (if I'm not mistaken) 2 Analogue Solutions' MX224
Mixer/Buffer Modules. Obviously the latter is not very economical.
Regards, Ingo
> wrote:
> > Hi Ingo,
> CSound
> compression ?)
> > thank you
> > at
> > > hello,
> > > loudness.
> > > file size: 429 kb
> > > 1. a114 original
> > > 4. blacet klangwerk
> > > best wishes
> > > ingo
> > hello antonio,
> Regards, Ingo
i usually use those mx224 buffers in front of the cgs real ring,
but i didn't in my example, because i wanted to show the
significant differences of the loudness.
anyway, if you use those buffers, the output level of
the cgs real ring is still much lower than on the other
ring modulators.
best wishes
ingo
RE: [Doepfer_a100] Re: comparing ring modulators
2005-11-15 by Zoran Bosnjak
Ingo,
thank you so much for the example! I like the CGS ring module the most. What
a pity it is not offered assembled. I still have to get the soldering lesson
#1 before trying to figure it out myself... (Does anybody offer basic
electronics course in Montreal?)
Zoran
>From: "selfoscillate" <synaptic_music@yahoo.com>
>Reply-To: Doepfer_a100@yahoogroups.com
>Subject: [Doepfer_a100] Re: comparing ring modulators
>Date: Tue, 15 Nov 2005 10:38:39 -0000
> > > hello antonio,
> > Regards, Ingo
>ring modulators.
>best wishes
>ingo
2005-11-15 by Tim Stinchcombe
Hi Ingo,
Thanks for the interesting comparisons! I'm quite surprised that
there is any difference at all between the original state and with c1
shorted - I'm wondering whether the A-111 sine-shaping can introduce
DC into the signal (I'll check it out when I get the chance). Since
the CGS one is so simple, I may have a go at simulating it to see
what it looks like - *if* I can mimic the transformers and germanium
diodes appropriately. It would also be interesting to hear how harsh
the EFM one sounds alongside these - from memory it is designed so
that it hard-switches one set of transistors in the MC1496, and so
introduces all the odd harmonics of one of the signals.
Also thanks for picking up on an error of mine, that the other cap to
try is in fact C1 and not C10 as I was calling it - I don't have the
benefit of the schematic in the service manual, and I obviously
saw 'C1 0.1u' on the silkscreen as 'C1 0' and hence C10, and once I'd
written it down, its fate was sealed! I have corrected the one gif I
uploaded to the files section.
Tim
> hello,
> loudness.
> file size: 429 kb
> 1. a114 original
> 4. blacet klangwerk
> best wishes
> ingo
Re: [Doepfer_a100] Re: comparing ring modulators
2005-11-16 by denis goekdag
it's really easy to assemble one or two cgs ringmods from the assembled
boards you can buy, just take an 8 hp blindplate, drill 6 8.2mm holes
for the s6 sockets, hot-glue the two cgs boards to the plate (the
transformer's "casing" allow this quite smoothly), wire the sockets,
done. it's a lovely ringmod. if you feed it with a high-power sine from
i.e. a testsignal generator (like a heathkit) and a microphone thru
preamp, you can get the exact sound of the imperial probe droid in The
Empire Strikes Back...Looooovely :-)
cheers,
denis
Am 15.11.2005 um 18:09 schrieb Zoran Bosnjak:
> Ingo,
> most. What
> lesson
> Regards,
> Zoran
>>>> hello antonio,
>>> Regards, Ingo
>> ring modulators.
>> best wishes
>> ingo
2005-11-16 by ilanode
--- In Doepfer_a100@yahoogroups.com, denis goekdag <q-art@g...>
assembled
holes
sockets,
> done.
Yes, probably the most simple DIY project around. The most
complicated part is to get in touch with Ken of CGS at least he has
never replied to my mails.
:( Ingo
> > Ingo,
> > most. What
soldering
> > lesson
basic
> > Regards,
> > Zoran
> >> From: "selfoscillate" <synaptic_music@y...>
> >>>> hello antonio,
thus
each
economical.
> >>> Regards, Ingo
> >> ring modulators.
> >> best wishes
> >> ingo
> > Yahoo! Groups Links
2005-11-16 by okiikahuna
I think you guys might have missed Doepfer's "other" ring modulator
in your otherwise exhaustive comparison.  The A-133 Polarizer is just
a 4 quadrant multiplier and seems to make a fine balanced modulator.
Just adjust the carrier for the least amount of leakage with no cv
applied, then put the modulator signal into the CV jack. You can vary
it continuously between balanced modulation and ampitude modulation
by turning the knob or applying an offset.  To me, the sound seems
most similar to the unmodded A-114, which raises lots of interesting
questions about the effect of DC v. AC coupling, since the A-133 is
clearly DC.
Although it has been a few years since I have played with one, I have
very fond memories of the sound of the Buchla 100 series ring
modulator.  Does anybody know what was in this circuit?  Was there
anything special about it?
K
> assembled
> holes
> sockets,
> > done.
> never replied to my mails. > :( Ingo
> > > Ingo,
> the
> > > most. What
> soldering
> > > lesson
> basic
> > > Regards,
> > > Zoran
<techmeier@w...>
> > >>>> hello antonio,
> thus
if
> the
> each
> economical.
> > >>> Regards, Ingo
ring,
> > >> ring modulators.
> > >> best wishes
> > >> ingo
> > > Yahoo! Groups Links
2005-11-17 by selfoscillate
hello,
i tried the a133 too, but i haven't recorded it, because i
wanted to compare only dedicated ring modulators.
you are right, the a133 can also be used to generate
ring modulator effects. damn, i should have recorded
that module too.
best wishes
ingo
--- In Doepfer_a100@yahoogroups.com, "okiikahuna" <okiikahuna@y...>
just
modulator.
vary
interesting
> clearly DC.
have
> K
> > assembled
> > holes
(the
> > sockets,
> > > done.
has
> > > > Ingo,
> > the
> > > > most. What
> > soldering
> > > > lesson
offer
> > basic
> > > > Regards,
> > > > Zoran
> <techmeier@w...>
> > > >>>> hello antonio,
> > thus
> if
> > the
> > each
> > economical.
> > > >>> Regards, Ingo
> ring,
> > > >> ring modulators.
> > > >> best wishes
> > > >> ingo
> > > > Yahoo! Groups Links
2005-11-17 by ilanode
Is the A133 really capable of both amplitude and ring modulation?
There's no info referring to this on the Doepfer HP. Anyhow, Ingo,
if you don't mind I'd like to hear some examples of amp/ring
modulation with the A133. Regards, Ingo
> hello,
> that module too.
> best wishes
> ingo
<okiikahuna@y...>
modulator
> just
> modulator.
cv
> vary
modulation
seems
> interesting
is
> > clearly DC.
> have
there
> > K
art@g...>
> > > assembled
8.2mm
> > > holes
> (the
> > > sockets,
> > > > done.
he
> has
> > > > > Ingo,
module
> > > the
> > > > > most. What
> > > soldering
> > > > > lesson
> offer
> > > basic
> > > > > Regards,
> > > > > Zoran
> > <techmeier@w...>
> > > > >>>> hello antonio,
and
> > > thus
different
> > if
> > > the
to
> > > each
MX224
> > > economical.
> > > > >>> Regards, Ingo
real
> > ring,
> > > > >> ring modulators.
> > > > >> best wishes
> > > > >> ingo
> > > > > Yahoo! Groups Links
hello ingo (the not self-oscillating :-)),
afaik the a133 is not really a ring modulator, but like a vca,
it can be used to achieve similar effects.
i'll record a sample using the a133, but i cannot
do this before weekend i guess. i still have some troubles
with my recording card. one time it works, the next time it
doesn't. computers can be a pain in the ....
best wishes
ingo
> > hello,
> > that module too.
> > best wishes
> > ingo
> <okiikahuna@y...>
> modulator
is
> > just
> > modulator.
> cv
can
> > vary
> modulation
> seems
> > interesting
133
> is
> > > clearly DC.
I
> > have
> there
> > > K
> art@g...>
> the
> > > > assembled
> 8.2mm
> > > > holes
plate
> > (the
> > > > sockets,
> > > > > done.
> he
> > has
> > > > > > Ingo,
> module
> > > > the
> > > > > > most. What
> the
> > > > soldering
> > > > > > lesson
> > offer
> > > > basic
> > > > > > Regards,
> > > > > > Zoran
> > > <techmeier@w...>
> > > > > >>>> hello antonio,
> and
> > > > thus
> different
> > > if
> > > > the
Amp
> to
> > > > each
> MX224
> > > > economical.
> > > > > >>> Regards, Ingo
> real
> > > ring,
> > > > > >> ring modulators.
> > > > > >> best wishes
> > > > > >> ingo
> > > > > > Yahoo! Groups Links
Great! I'll wait patiently. Regards, Ingo
> best wishes
> ingo
modulation?
Ingo,
> > > hello,
> > > that module too.
> > > best wishes
> > > ingo
> > <okiikahuna@y...>
<techmeier@w...>
> > modulator
Polarizer
> is
> > > just
> > > modulator.
no
> > cv
> can
> > > vary
> > modulation
> > seems
> > > interesting
> 133
> > is
> > > > clearly DC.
one,
> I
> > > have
ring
> > there
> > > > K
> > art@g...>
from
> > the
> > > > > assembled
6
> > 8.2mm
> > > > > holes
> plate
> > > (the
> > > > > sockets,
> > > > > > done.
least
> > he
> > > has
> > > > > > > Ingo,
> > module
> > > > > the
> > > > > > > most. What
get
> > the
> > > > > soldering
> > > > > > > lesson
anybody
> > > offer
> > > > > basic
> > > > > > > Regards,
> > > > > > > Zoran
> > > > <techmeier@w...>
> > > > > > >>>> hello antonio,
VCOs
> > and
> > > > > thus
> > different
> > > > if
> > > > > the
> Amp
> > to
> > > > > each
> > MX224
very
> > > > > economical.
> > > > > > >>> Regards, Ingo
> > real
> > > > ring,
other
> > > > > > >> ring modulators.
> > > > > > >> best wishes
> > > > > > >> ingo
> > > > > > > Yahoo! Groups Links
2005-11-17 by okiikahuna
I think that the only "real" ring modulator among the bunch is the
CGS unit. I will explain my own limited understanding of this, if
anybody cares. (If somebody with more technical knowledge sees a
mistake, please correct me)
The term "ring modulator" refers to a a certain way of
acheiving "four quadrant multiplication." It is called "ring"
modulation because the circuit uses four diodes arranged in what
looks like a ring in the circuit diagram.  The only unit that
actually uses this circuit is the CGS.
The term "Four quadrant multiplication" just means a kind of
amplitude modulation where a negative control voltage will invert the
carrier signal.  Here's an explanation of the this term: A regular
VCA is a "two quadrant multiplier." The control voltage "multiplies"
the signal at the input.  So, a zero signal gives no output because 0
times anything equals zero.  The input signal can be positive or
negative, but the multiplier signal can only be positive, a negative
control voltage has no effect.  So there are two "quadrants."
positive control and positive input or positive control and negative
input.
So, "Four quadrant multiplier" just means that the control voltage
can be negative.  When a negative multiplies a positive, it gives a
negative, so a negative signal inverts the input.  This is what
all "ring modulators" do, regardless of whether they actually use the
diode ring circuit or not.  (However, different circuits clearly add
various kinds of additional artifacts, judging by the different
sounds Ingo got.)
So, changing "ring" modulation to amplitude modulation in a four
quadrant multiplier (Like the A-133) just means changing the control
signal from bipolar to all positive.  This can be done by adding a
positive offset voltage to a bipolar control voltage.
Of course, this is really just tech-trivia since it doesn't help
anybody to figure out what sounds you will get by doing this. Only
way to figure that out is by doing what we all do: plug wires and
turn knobs.
K
> best wishes
> ingo
Ingo,
> > > hello,
> > > that module too.
> > > best wishes
> > > ingo
> > <okiikahuna@y...>
<techmeier@w...>
> > modulator
> is
> > > just
> > > modulator.
no
> > cv
> can
> > > vary
> > modulation
> > seems
> > > interesting
> 133
> > is
> > > > clearly DC.
one,
> I
> > > have
> > there
> > > > K
> > art@g...>
> > the
> > > > > assembled
> > 8.2mm
> > > > > holes
> plate
> > > (the
> > > > > sockets,
> > > > > > done.
least
> > he
> > > has
> > > > > > > Ingo,
> > module
> > > > > the
> > > > > > > most. What
> > the
> > > > > soldering
> > > > > > > lesson
anybody
> > > offer
> > > > > basic
> > > > > > > Regards,
> > > > > > > Zoran
> > > > <techmeier@w...>
> > > > > > >>>> hello antonio,
VCOs
> > and
> > > > > thus
> > different
> > > > if
> > > > > the
> Amp
> > to
> > > > > each
> > MX224
very
> > > > > economical.
> > > > > > >>> Regards, Ingo
> > real
> > > > ring,
> > > > > > >> ring modulators.
> > > > > > >> best wishes
> > > > > > >> ingo
> > > > > > > Yahoo! Groups Links
AFAK the difference btn amplitude modulation and ring modulation is
that only in the latter the carrier freq is no longer present at the
output... Wether this is done by an IC or diodes is soundwise of
interest but doesn't affect the label. Regards, Ingo
because 0
negative
negative
> input.
a
add
> sounds Ingo got.)
control
> turn knobs.
> K
> > best wishes
> > ingo
modulation?
> Ingo,
> > > > hello,
> > > > that module too.
> > > > best wishes
> > > > ingo
> > > <okiikahuna@y...>
> <techmeier@w...>
> > > modulator
Polarizer
> > is
> > > > just
> > > > modulator.
with
> no
> > > cv
You
> > can
> > > > vary
> > > modulation
sound
> > > seems
> > > > interesting
A-
> > 133
> > > is
> > > > > clearly DC.
> one,
> > I
> > > > have
ring
Was
> > > there
> > > > > K
> > > art@g...>
from
> > > the
> > > > > > assembled
drill 6
> > > 8.2mm
> > > > > > holes
> > plate
> > > > (the
wire
> the
> > > > > > sockets,
> > > > > > > done.
most
> least
> > > he
> > > > has
> > > > > > > > Ingo,
ring
> > > module
> > > > > > the
> > > > > > > > most. What
get
> > > the
> > > > > > soldering
> > > > > > > > lesson
> anybody
> > > > offer
> > > > > > basic
> > > > > > > > Regards,
> > > > > > > > Zoran
modulators
> > > > > <techmeier@w...>
> > > > > > wrote:
> > > > > > > >>> --- In
> > > > > > > >>>> hello antonio,
> VCOs
> > > and
> > > > > > thus
> > > different
> > > > > if
> > > > > > the
Op
> > Amp
> > > to
> > > > > > each
Solutions'
> > > MX224
> very
> > > > > > economical.
> > > > > > > >>> Regards, Ingo
cgs
> > > real
> > > > > ring,
show
> the
of
other
> > > > > > > >> ring modulators.
> > > > > > > >> best wishes
> > > > > > > >> ingo
> > > > > > > > Yahoo! Groups Links
That's my understanding as well:  Just to clarify terms: An
ideal "balanced" modulator (4 quadrant multiplier), where a negative
modulator inverts the carrier, results in sum and difference signals
with no carrier or modulator present in the output.  Classic
amplitude modulation (2 quadrant multiplication), where the carrier
is not inverted, does not eliminate the carrier signal from the
output.
    You're absolutely right that the term "ring modulator" is
commonly used to refer to any balanced modulator (4 quadrant
multiplier), not just one constructed using the diode ring.
    The point of the post was just to clarify the the terms and
their orgins, not to confuse things with fancy sounding words. Since
the important thing is sound, not terminology, its not really all
that important.
    However, Ingo's CGS recording seems to show that a "real" ring
modulator sounds quite different from the balanced modulators we've
all gotten accustomed to.  I wonder if our good friend Dieter
Doepfer would be interested in making a "real" diode ring modulator
that also has some active electronics to eliminate the pesky signal
loss in the CGS passive circuit.  Would there be any interest in
this?
K
is
<okiikahuna@y...>
if
invert
> the
regular
> because 0
> negative
> negative
> > input.
voltage
gives
> a
use
> the
> add
> > sounds Ingo got.)
> control
a
Only
and
> > turn knobs.
> > K
> > > best wishes
> > > ingo
<techmeier@w...>
> modulation?
> > Ingo,
> > > > > hello,
> > > > > that module too.
> > > > > best wishes
> > > > > ingo
> > > > <okiikahuna@y...>
> > <techmeier@w...>
ring
> > > > modulator
> Polarizer
> > > is
> > > > > just
balanced
> > > > > modulator.
> with
> > no
> > > > cv
> You
> > > can
> > > > > vary
> > > > modulation
> sound
> > > > seems
> > > > > interesting
> A-
> > > 133
> > > > is
> > > > > > clearly DC.
with
> > one,
> > > I
> > > > > have
> ring
> Was
> > > > there
> > > > > > K
> > > > art@g...>
> from
> > > > the
> > > > > > > assembled
> drill 6
> > > > 8.2mm
> > > > > > > holes
> > > plate
> > > > > (the
> wire
> > the
> > > > > > > sockets,
> > > > > > > > done.
> most
> > least
> > > > he
> > > > > has
> > > > > > > > > Ingo,
> ring
> > > > module
> > > > > > > the
> > > > > > > > > most. What
to
> get
> > > > the
> > > > > > > soldering
> > > > > > > > > lesson
> > anybody
> > > > > offer
> > > > > > > basic
> > > > > > > > > Regards,
> > > > > > > > > Zoran
> modulators
> > > > > > <techmeier@w...>
> > > > > > > wrote:
> > > > > > > > >>> --- In
> > > > > > > > >>>> hello antonio,
> > VCOs
> > > > and
> > > > > > > thus
be
> > > > different
> > > > > > if
> > > > > > > the
an
> Op
> > > Amp
> > > > to
> > > > > > > each
> Solutions'
> > > > MX224
not
> > very
> > > > > > > economical.
> > > > > > > > >>> Regards, Ingo
> cgs
> > > > real
> > > > > > ring,
> show
> > the
level
> of
> other
> > > > > > > > >> ring modulators.
> > > > > > > > >> best wishes
> > > > > > > > >> ingo
> > > > > > > > > Yahoo! Groups Links
2005-11-18 by selfoscillate
this would be interesting of course,
but there is one thing which we have to think about.
ken stone uses germanium diodes in his circuit which are
more than 30 years old, he recycles them from old computers.
i'm not sure if the needed diodes are easy to get for dieter.
best wishes
ingo
negative
signals
> output.
Since
> that important.
> this?
> K
> is
> the
> <okiikahuna@y...>
> the
> if
a
what
> invert
> > the
> regular
> > because 0
or
> > negative
> > negative
> > > input.
> voltage
> gives
> > a
> use
> > the
clearly
> > add
> > > sounds Ingo got.)
four
> > control
adding
> a
help
> Only
> and
> > > turn knobs.
> > > K
> > > > best wishes
> > > > ingo
> <techmeier@w...>
> > modulation?
Anyhow,
> > > Ingo,
amp/ring
> > > > > > hello,
> > > > > > that module too.
> > > > > > best wishes
> > > > > > ingo
> > > > > <okiikahuna@y...>
> > > <techmeier@w...>
> ring
> > > > > modulator
> > Polarizer
> > > > is
> > > > > > just
> balanced
> > > > > > modulator.
> > with
> > > no
> > > > > cv
jack.
> > You
> > > > can
> > > > > > vary
ampitude
> > > > > modulation
> > sound
> > > > > seems
of
> > > > > > interesting
> the
> > A-
> > > > 133
> > > > > is
> > > > > > > clearly DC.
> with
> > > one,
> > > > I
> > > > > > have
series
> > ring
circuit?
> > Was
> > > > > there
> > > > > > > K
> > > > > art@g...>
ringmods
> > from
> > > > > the
> > > > > > > > assembled
> > drill 6
> > > > > 8.2mm
> > > > > > > > holes
> the
> > > > plate
> > > > > > (the
> > wire
> > > the
> > > > > > > > sockets,
> > > > > > > > > done.
> > most
at
> > > least
> > > > > he
> > > > > > has
> > > > > > > > > > Ingo,
> > ring
> > > > > module
> > > > > > > > the
> > > > > > > > > > most. What
> to
> > get
> > > > > the
> > > > > > > > soldering
> > > > > > > > > > lesson
> > > anybody
> > > > > > offer
> > > > > > > > basic
> > > > > > > > > > Regards,
> > > > > > > > > > Zoran
> > modulators
> > > > > > > <techmeier@w...>
> > > > > > > > wrote:
> > > > > > > > > >>> --- In
> > > > > > > > > >>>> hello antonio,
> the
> > > VCOs
> > > > > and
> > > > > > > > thus
> be
> > > > > different
> > > > > > > if
> > > > > > > > the
> an
> > Op
> > > > Amp
> > > > > to
> > > > > > > > each
> > Solutions'
> > > > > MX224
> not
> > > very
> > > > > > > > economical.
> > > > > > > > > >>> Regards, Ingo
> > cgs
> > > > > real
> > > > > > > ring,
> > show
> > > the
> level
> > of
> > other
> > > > > > > > > >> ring modulators.
> > > > > > > > > >> best wishes
> > > > > > > > > >> ingo
> > > > > > > > > > Yahoo! Groups Links
AW: [Doepfer_a100] Re: comparing ring modulators
2005-11-18 by Dieter Doepfer
> this?
Though the ringmodulator (the original one with 4 diodes and a transformer)
is a well-known circuit I do not want to copy Ken Stones idea of a module
that uses just this circuit. Adding an amplifier would not really change
very much.
I'd recommend to ask Ken Stone to add an amplifier to his circuit. I'm sure
that this is not a problem for him.
Another possibility would be to manufacture Ken Stone's RM under licence,
e.g. by purchasing the diodes and transformer from him and adding an
amplifier in our module. But I'm not sure if Ken will agree to this
procedure.
Best wishes
Dieter Doepfer
This would not really be a problem. E.g. matched A-113 Germanium diodes made
by Tungsram are available on the market.
Best wishes
Dieter Doepfer
2005-11-18 by ilanode
Hello Dieter, Ken has licensed some of his circuits to Metalbox
(FracRak compatible) and Cyndustries (Modcan compatible), added to a
Serge cicuit for Banalogue (finaly: Euro Rack compatible) thus he
probably would license the RRM to you. (None of the above offering
the RRM.)
I doubt that he will add buffers to the circuits he's selling. Since
he's supplies the DIY-community he surely is expecting the user to
add these goodies if thought neccessary.
I'd love to see an RRM with a pots at the inputs so one could choose
freely btn buffered inputs and non buffered which are loading back
on the VCOs and an amp to bring the output back to the common signal
level. Regards, Ingo
--- In Doepfer_a100@yahoogroups.com, "Dieter Doepfer"
ring
we've
modulator
signal
> > this?
transformer)
module
change
> very much.
I'm sure
licence,
an
> procedure.
> Best wishes
> Dieter Doepfer
2005-11-18 by Anton Coops
A variation on this theme - at least I think it is, but I'm no expert - is
the so called 'difference tone'. If you combine two sine waves f1 and
f2, that are far enough apart in frequency, you will be able to hear a
'difference tone' f1 - f2. Does anybody on the list have enough
physics background to tell if this is basically the same thing going
on? Or is this something else? Or is it too off topic :)
Classic
> output.
> that important.
> this?
> K
> is
> the
> <okiikahuna@y...>
> the
> if
> invert
> > the
> regular
> > because 0
> > negative
> > negative
> > > input.
> voltage
> gives
> > a
> use
> > the
> > add
> > > sounds Ingo got.)
> > control
> a
> Only
> and
> > > turn knobs.
> > > K
> > > > best wishes
> > > > ingo
> <techmeier@w...>
> > modulation?
> > > Ingo,
> > > > > > hello,
> > > > > > that module too.
> > > > > > best wishes
> > > > > > ingo
> > > > > <okiikahuna@y...>
> > > <techmeier@w...>
> ring
> > > > > modulator
> > Polarizer
> > > > is
> > > > > > just
> balanced
> > > > > > modulator.
> > with
> > > no
> > > > > cv
> > You
> > > > can
> > > > > > vary
> > > > > modulation
> > sound
> > > > > seems
> > > > > > interesting
> the
> > A-
> > > > 133
> > > > > is
> > > > > > > clearly DC.
> with
> > > one,
> > > > I
> > > > > > have
> > ring
> > Was
> > > > > there
> > > > > > > K
> > > > > art@g...>
> > from
> > > > > the
> > > > > > > > assembled
> > drill 6
> > > > > 8.2mm
> > > > > > > > holes
> the
> > > > plate
> > > > > > (the
> > wire
> > > the
> > > > > > > > sockets,
> > > > > > > > > done.
> > most
> > > least
> > > > > he
> > > > > > has
> > > > > > > > > > Ingo,
> > ring
> > > > > module
> > > > > > > > the
> > > > > > > > > > most. What
> to
> > get
> > > > > the
> > > > > > > > soldering
> > > > > > > > > > lesson
> > > anybody
> > > > > > offer
> > > > > > > > basic
> > > > > > > > > > Regards,
> > > > > > > > > > Zoran
> > modulators
> > > > > > > <techmeier@w...>
> > > > > > > > wrote:
> > > > > > > > > >>> --- In
> > > > > > > > > >>>> hello antonio,
> the
> > > VCOs
> > > > > and
> > > > > > > > thus
> be
> > > > > different
> > > > > > > if
> > > > > > > > the
> an
> > Op
> > > > Amp
> > > > > to
> > > > > > > > each
> > Solutions'
> > > > > MX224
> not
> > > very
> > > > > > > > economical.
> > > > > > > > > >>> Regards, Ingo
> > cgs
> > > > > real
> > > > > > > ring,
> > show
> > > the
> level
> > of
> > other
> > > > > > > > > >> ring modulators.
> > > > > > > > > >> best wishes
> > > > > > > > > >> ingo
> > > > > > > > > > Yahoo! Groups Links
That's one of the basic principles of the frequency shifter. I have a word
document that explains all the trigonometric formulas behind the RM/FS
(sorry the words are in German). If anybody's interested I can send him the
file (excerpt from the A-126 service manual).
These are the most important formulas (a and b are the two inputs)
1. For RM only:
·	sin a x sin b = cos(a-b) - cos(a+b)
or
·	cos a x cos b = cos(a-b) + cos(a+b)
Sine and cosine have a phase shift of 90 degree (in other words: shifting a
sine signal by 90 degrees leads to the cosine). But one cannot hear the
difference between sine and cosine as long as no phase-fixed reference
signal is available. Consequently you will hear the sum cos(a+b) and
difference cos(a-b) in the RM output. As each audio signal can be treated as
a sum of sine signals (Fourier analysis) any audio signals can be used.
The multiplications (sin a x sin b and the same with cosine) are realized
with the RM (four quadrant multiplier).
2. For additional frequency shifting:
·	sum of the above formulas: sina sinb + cosa cosb = 2 cos(a-b)
·	difference of the above formulas: sina sinb - cosa cosb = -2 cos(a+b)
That's how in principle the frequency shifter works (2 RM for the sine and
cosine and a simple adder and subtractor).
For frequency shifting "b" is a sine/cosine oscillator (so-called quadrature
oscillator) that generates sine and cosine simultaneously. "a" is the audio
signal to be frequency-shifted. To obtain the cosine of this signal a
so-called dome filter is required that generates a 90 degree phase shift of
the signal over a wide frequency range (~ 60Hz - 12kHz for the A-126). This
is because sine and cosine have a phase shift of 90 degree.
I hope that's not too much mathematics for the weekend - but you have been
asking ....
Best wishes
Dieter Doepfer
Re: AW: [Doepfer_a100] Re: comparing ring modulators
What a versatile principle!
The word document would be out of my category, but maybe
another recommendation? I would like to know more about 'general'
properties of waves. Because as this example also demonstrates
there are a lot of properties that are independent of the medium that
the wave is in: air-pressure, electrons, whatever. Are there good
books or websites on this subject? A little mathematics is ok :-)
> 1. For RM only:
> or
> asking ....
> Best wishes
> Dieter Doepfer
Books About 'Waves'
2005-11-20 by sfrules
I loved this book.  It describes the physics of sound and how sound
is produced by
various musical instruments.  It's a great source for physical
modelling synthers.
The Acoustical Foundations of Music (Hardcover)
by John Backus   http://www.amazon.com/gp/product/
0393090965/102-3146998-9268930?v=glance&n=283155&s=books&v=glance
sfrules
PS.  Amazon offered it paired with a book by Harry Olson.  He was one
of the designers of the Bell Labs Synth...
Re: [Doepfer_a100] Books About 'Waves'
2005-11-20 by Anton Coops
thank you!
I would also like to read some more about general physics of waves,
not specifically applied to acoustics, but a nice readable book or a
good website about all the basic properties that are also found in
electronics, light etc.
I couldn't think of anything else than the physics course that MIT has
put online, but that's like going back to school... other (less dry)
suggestions would be appreciated
> is produced by
> modelling synthers.
> sfrules
