Doepfer
MAQ 16/3 eprom
MAQ 16/3 eprom
2005-11-11 by atuzzi
Do you know the MAQ sequencer eprom style?
Is it a 27256 or 27c256 or 27512 or 27c512?
or something completely different ?
thanks
at
AW: [Doepfer_a100] MAQ 16/3 eprom
2005-11-11 by Dieter Doepfer
Normally 27C256. But even a 27C512 can be used. In this case the jumper
labelled "A15/27C512" has to be installed (for 27C256 the address line A15
is not used but for 27C512 it is necessary).
For the old versions of MAQ16/3 (version 1 and 2) an 27C128 or 27128 was
used. But these versions are out of production since about 1996.
If you remove the label on the EPROM you can read the EPROM type that is
used.
Best wishes
Dieter Doepfer
> [mailto:Doepfer_a100@yahoogroups.com]Im Auftrag von atuzzi
> Gesendet: Freitag, 11. November 2005 11:00
> Betreff: [Doepfer_a100] MAQ 16/3 eprom
> Hi,
> thanks
> at
