toner
2007-02-02 by Lez
2007-02-02 by Lez
Does different toner have different melting points etc, wondering if when I fianlly have to refil this old 4l, if I should get black, or blue/red whatever -- Lez
2007-02-02 by Stefan Trethan
On Fri, 02 Feb 2007 17:22:02 +0100, Lez <lez.briddon@...> wrote: > Does different toner have different melting points etc, wondering if > when I fianlly have to refil this old 4l, if I should get black, or > blue/red whatever I don't think it depends on color, there seem to be differences between the black ones as well. We had someone here selling refills a while ago, maybe he is still here and can offer advice or even product. Generally i would tend towards the original cartridges rather than remanufactured ones or even refilling, i had bad luck with those. Ebay is a good source for original carts that are past their use by date but still work fine. I am told good refill toner is just the same, but i'm still reluctant. I used old copier toner of which i have lots and lots of in HP IIID carts, and it must be very different (finer maybe). It would apply way too much to the magnetic transfer roller, and i had to completely remove those "spacers" for the scraper. It will work just fine for text prints now, but not so good for PCBs. Anyway, it would be interesting if someone knows a bulk toner that works well, but it may still not work the same in all printers. ST
2007-02-08 by dagmargoodboat
--- In Homebrew_PCBs@yahoogroups.com, "Stefan Trethan" <stefan_trethan@...> wrote: > > On Fri, 02 Feb 2007 17:22:02 +0100, Lez <lez.briddon@...> wrote: > > > Does different toner have different melting points etc, > > wondering if when I fianlly have to refil this old 4l, > >if I should get black, or blue/red whatever I've measured melting points for two toners, the original toner in my HP LaserJet 6L, and the eBay toner I used to refill my Samsung ML-1710. They don't abruptly transition from solid to liquid, but become soft and waxy, then sticky, then gooey, so "melting point" needs clarification. The HP toner could be smeared with a hot iron at 103+/-3 deg. C. The refill toner smeared at 99+/-2 deg. C. There's a decorative metallic transfer film you can iron on to laser-printed text. I measured the temperatures needed to transfer: 110 +/- 3 deg C for the HP, and 81 +/- 3 deg C for the refill stuff. > Generally i would tend towards the original cartridges > rather than remanufactured ones or even refilling, i > had bad luck with those. Ebay is a good source for > original carts that are past their use by date but still > work fine. I am told good refill toner is just the same, > but i'm still reluctant. The refill toner I used was from TonerKits on eBay-- cheap, great service. I just poured it in & prints as well or better on paper than the original. No differences for toner transfer noticed. > I used old copier toner of which i have lots and lots > of in HP IIID carts, and it must be very different > (finer maybe). It would apply way too much to the > magnetic transfer roller, and i had to completely > remove those "spacers" for the scraper. It will work > just fine for text prints now, but not so good for PCBs. > > Anyway, it would be interesting if someone knows a bulk > toner that works well, but it may still not work the same > in all printers. > > ST I've no idea how suitable it is, but I have 1,4Kg of Toshiba T-6560 toner! James Arthur
