new TT idea
2007-02-03 by Lez
I had a sheet of paper jam in the machine, so the toner on it just wiped off, it was not fused but it was 'stuck' provided I didn't waft it around in the air. I fed this sheet through the laminator, it stuck to the copper no problem, even with the low temp laminator I have. Going to try that again later, I just thought if I wedge the rollers of the fuser apart so it applies no pressure or does not touch the paper at all, I should be able to get a sheet out unfused but fully printed. It will need to be handled carefully, but were used to that........ -- Lez
