Homebrew PCBs
fume cupboard stage using super glue like finger print recovery? ??
2007-03-16 by vsmvdd
will this work with any ink i ask myself
skin is a kind of plastic also
ink esp the pigment ones seems to me
has many of the same properties as oil the dye based around the same
but copper isnt and will ignore the cyano acrilate fumes
as long as its solvent clean
and oil free
we have all seen the cop shows
maybe this technique can be used to seal any inkjet
prints to resist well enought
im probably taking ideas mentioned
ive not had a really good look thru
the heeps of pages on this great site...
Re: fume cupboard stage using super glue like finger print recovery? ??
2007-03-16 by docstein99
Well, you could explore that method, but it then would add a burden to
the delicate process.
I feel curing the ink to the board may best lye in PREPARING the board
before you print.  Somehow coat the board with a chemical that will let
the ink adhere and seal, and still allow the etch to disolve the copper.
If only there was a good chemist around, I am sure that would be real
handy right now.
to
why???  its just one more stage for a good board
and no cooking of the board or further fixing past a drying stage
so no need for heat  as the fumes will corrode the surface oils to
produce very hard carbon deposits
so it takes a stage away while introducing one
board
let
copper.
im not so sure your right here
real
> handy right now.
ye  and im pretty sure he will agree with me
{i have a higher in chemisty and racked my brain before i posted }
finger oil is  much like any oil it forms
hard carbon when expose to these rancid fumes
but copper areas wont be affected atall
well its worth a go
ive got a claria pigment based inkjet print drying
{cd pcb i tried earlier reprinted}
so ill set up something to fume it in tomorrow {a plastic stowawaybox}
and a little oil burner pad for burning oil
burden
> to
> board
will
> let
> copper.
> real
> > handy right now.
> well its worth a go
stowawaybox}
