Homebrew PCBs
Etchants is use
Etchants is use
2007-07-05 by Kamal Shankar
I would be interested in getting a good idea of what
are the etchants being used.
AFAIK, they are :
1. Hot FeCl3
2. Muriatic Acid + Hydrogen Peroxide
3. Copper chloride
And I got that hopefully, in order of popularity.
If all these work, the 2nd choice seems to be easier
to get and use; so why is the first so popular.
I myself use it, and the reason being people I know
who do it professionally use it too ?
What's the reason? Financial? (The 2nd choice is a
little bit cheaper than the first) Speed? Ease of
storage?
I would like to find it out from you, and do give
feedback of what all etchants you used and what you
finally settled with and why.
Cheers
KamalS
Now that's room service!  Choose from over 150,000 hotels
in 45,000 destinations on Yahoo! Travel to find your fit.
http://farechase.yahoo.com/promo-generic-14795097
Re: [Homebrew_PCBs] Etchants is use
2007-07-05 by Leon
To: "Homebrew_PCBs" <Homebrew_PCBs@yahoogroups.com>
Sent: Thursday, July 05, 2007 7:41 AM
Subject: [Homebrew_PCBs] Etchants is use
> AFAIK, they are :
> 1. Hot FeCl3
> 3. Copper chloride
> storage?
FeCl3 is easier to obtain than high strength H2O2, although HCl is easy to
get old of (it's used for cleaning drains and brickwork).
Leon
2007-07-05 by Adam Seychell
> AFAIK, they are :
> 1. Hot FeCl3
> 3. Copper chloride
> storage?
As you noticed, there are a number of etchants used by hobbyists.  That
shows there are exists pros and cons with all of them and each suit
users differently. FeCl3 has the advantage of indefinite shelf life
(H2O2 decomposes over time), quick (but not the quickest), and easily to
use (no mixing or preparation) and wide availability.
I use alkaline ammonia chloride etchant because I etch with
electroplated tin as the etch resists, and all acid etchants attack tin.
This etchant is very rare among hobbyists because it really needs spray
etcher or sealed chamber to operate due to ammonia fumes. It also needs
complicated chemical analysis to make sure it stays working.
2007-07-05 by Lez
On 05/07/07, Leon <leon355@...> wrote:
>  From: "Kamal Shankar" <kbshankar2000@...>
>  > AFAIK, they are :
>  > 1. Hot FeCl3
>  > 3. Copper chloride
because in the UK its all you can buy off the shelf.
Chemicals are not really sold in the UK, even drain cleaner is weak.
If you want chemicals as such then we only have industrial suppliers
so drums etc, paperwork, just not viable.
If its something a drugstore would have, they still probably would not
sell, looking upon you with suspicion as either a bomber or murderer.
So, for UK fe is the big big winner.
we now have sharpies though, only just made it over and only in chunky
pen sizes with 2mm tips, being pushed on adverts for marking clothes /
shoes and other items where big print is needed. (so I'll stick with a
white uniball px203 for now)
Electroplated tin and PTH
2007-07-05 by Andrew
> Adam wrote:
> <SNIP>
> I etch with electroplated tin as the etch
> because it really needs spray etcher or sealed
> also needs complicated chemical analysis to
Adam, have you dropped the CuCl in favour of
the alkaline etchant because of problems with
through hole plating ?
Is the whole tent and etch thing problematic?
Re: Etchants is use
2007-07-06 by Jeffrey Jenkins
--- In Homebrew_PCBs@yahoogroups.com, Kamal Shankar
> storage?
I previously used ferric chloride heated to near-boiling in the
microwave for years but after I learned about HCl/H2O2 on this group I
gave it a try and haven't looked at FeCl3 since! Specifically, I use
"muriatic acid" (31.45% HCl) that I buy off the shelf at Home Depot
for $9/2Gal (that's 7.5L to you metric folks) and regular 3% hydrogen
peroxide solution from any old drugstore (although in this particular
case I bought it from Sam's Club for something like $3/2qt. (~1.9L).
Besides being at least an order of magnitude cheaper than FeCl3, it
also etches boards a lot faster and is transparent. I've even etched
some fine pitch (0.5mm) SMT boards with very good results. This
etchant is truly a no-brainer choice IF you can get the chemicals
without a lot of hassle (otherwise the "time saved" hassn't really
been saved).
-Jeff
Re: [Homebrew_PCBs] Re: Etchants is use
2007-07-07 by JanRwl@AOL.COM
In a message dated 7/6/2007 5:32:49 P.M. Central Daylight Time,
tesseract@... writes:
I  previously used ferric chloride heated to near-boiling in the microwave
for  years but after I learned about HCl/H2O2 on this group I gave it a try and
haven't looked at FeCl3 since!<<
I heat FeCl3, too.  But do you heat the HCl/H2O2 as well,  or use it at "room
temp"?
Thanks!   Jan Rowland
************************************** See what's free at http://www.aol.com.
Re: [Homebrew_PCBs] Electroplated tin and PTH
2007-07-07 by Adam Seychell
Andrew wrote:
>  > Adam wrote:
>  > <SNIP>
Andrew, thats right. I gave up on tent and etch because there were
always a few holes which failed to seal properly thus destroying the
plating during etch. Unless the pads has sufficient hole coverage and
your hole drilling accuracy to spot on, then the tent method can be
unreliable.  But don't get me wrong, pattern plating has its own set of
problems too. It is a little more work adding the tin step and dealing
with ammonia etchants, but I think the results are more reliable. The
ammonia chloride etchant is very fast too compared to aerated CuCl. I
run it at ambient temp which is 5~6\ufffdC this time of the year and still
works ok for me.
Re: Etchants is use
2007-07-07 by lcdpublishing
Jeff,
What is the ratio you use for that?  How long does it last? Which to
you add to which?  (Peroxide to acid or acid to peroxide)
Any other tips or info would be great.  When my current batch of
Ferric Chloride dies, I would like to use something else :-(
--- In Homebrew_PCBs@yahoogroups.com, "Jeffrey Jenkins"
> > storage?
group I
use
hydrogen
particular
(~1.9L).
etched
> been saved).
> -Jeff
Re: Etchants is use
2007-07-08 by h500ca
I use copper chloride since it can be regenerated indefinitely by
bubbling or by adding a few drops of 30% h202.  Concentrated h202
should be readily available locally.  Hydroponic suppliers usually has
it.  Pool chemical places sells it as a non-chlorine water treatment,
under the name "Baquacil".  I bought mine as "food grade h202" from a
local health food store. ($20/liter)
Re: Etchants is use
2007-07-08 by Jeffrey Jenkins
--- In Homebrew_PCBs@yahoogroups.com, "lcdpublishing"
<lcdpublishing@...> wrote:
> Jeff,
The ratio is 1 volume HCl to 2 volumes H2O2 and you Always Add Acid,
as they say (e.g. - 200mL h2o2 added to 100mL HCl). The solution heats
up maybe 10-15C when the peroxide is added but nothing spectacular.
Boards etch in 3-4 minutes with the usual agitation or "hand-rubbing"
- I wear nitrile (blue) gloves when using it because peroxyacids cause
hellacious skin burns, much worse than the pure acid does. That said,
the solution is very easy to work with and naturally decomposes back
to the acid and water (plus dissolved copper chloride) in a matter of
hours. I've been saving the used solution in a jug and will likely
precipitate out the copper with sodium bicarbonate (baking soda) or
hydroxide (lye) before dumping the rest down the drain (it'll then be
salt water - no harm there!).
All things considered I feel it is a much better etching process than
Ferric Chloride and less fussy than sodium or ammonium persulfate
(which are simply salts of peroxysulfuric acid, so they are
essentially a neutral pH (sodium salt) or slightly acidic (ammonia
salt) version of this process).
Obviously, I have some grasp of the chemistry here which is why I
didn't hesitate to give this etchant a try, but I wouldn't say it
requires any special knowledge to use it well or safely. I strongly
recommend that it only be used outside because the HCl fumes quite a
bit and that a garden hose be kept nearby to flood any spills.
-Jeff
Re: Etchants is use
at "room
> temp"?
> Thanks!   Jan Rowland
It warms up a little when you add the peroxide, so let's say it is
used at around 20F above "room temp". You really want to make and use
this stuff outside because of the HCl fumes (which actually *diminish*
after mixing with the peroxide), so heating it up in the microwave or
on the stove would probably be a "recipe" for a kitchen disaster...
pardon the bad pun.
-Jeff
Re: Etchants is use
2007-07-08 by pork_u_pine2000
I have been experimenting with H2O2 + HCl.  I just don't like ferric
chloride much.  It's just nasty stuff.  And I was also very surprised
to find 35% H2O2 at my local 'natural' food store for about that
price.  I usually stay away from their 'nutraceuticals' department
because I wouldn't want to ingest anything that they sell, but for
dissolving  copper I make an exception.  The H2O2 is conspicuously
labeled 'dilute before using', though they avoid indicating what you
might want to use it for...
2007-07-09 by Leon
To: <Homebrew_PCBs@yahoogroups.com>
Sent: Sunday, July 08, 2007 8:57 PM
Subject: [Homebrew_PCBs] Re: Etchants is use
Why do 'health' food shops sell it? 8-)
Leon
2007-07-09 by Roland F. Harriston
Leon:
Quote from some health literature:
> "The following is only a partial listing of conditions in which H202
> therapy has been used successfully. (Many of these conditions are
> serious, if not life-threatening. It is highly recommend that  you
> seek the advice and guidance of a doctor experienced in the use of
> these techniques.)"
>     Allergies Headaches
>     Altitude Sickness Herpes Simplex
>     Alzheimer's Herpes Zoster
>     Anemia HIV Infection
>     Arrhythmia Influenza
>     Asthma Insect Bites
>     Bacterial Infections Liver Cirrhosis
>     Bronchitis Lupus Erythematosis
>     Cancer Multiple Sclerosis
>     Candida Parasitic Infections
>     Cardiovascular Disease Parkinsonism
>     Cerebral Vascular Disease Periodontal Disease
>     Chronic Pain Prostatitis
>     Diabetes Type 11 Rheumatoid Arthritis
>     Diabetic Gangrene Shingles
>     Diabetic Retinopahty Sinusitis
>     Digestion Problems Sore Throat
>     Epstein-Barr Infection Ulcers
>     Emphysema Viral Infections
>     Food Allergies Warts
>     Fungal Infections Yeast Infections
>     Gingivitis
Roland F. Harriston
"The Pedantic Douche"
Leon wrote:
> From: "pork_u_pine2000" <wittend@wwrinc. com
> <mailto:wittend%40wwrinc.com>>
> To: <Homebrew_PCBs@ yahoogroups. com
> <mailto:Homebrew_PCBs%40yahoogroups.com>>
> Leon
2007-07-09 by Leon
Sent: Monday, July 09, 2007 7:19 AM
Subject: Re: [Homebrew_PCBs] Re: Etchants is use
> Leon:
>> these techniques.)"
>>     Allergies Headaches
>>     Asthma Insect Bites
>>     Gingivitis
Perhaps we ought to drink it as well as making our PCBs with it. 8-)
Leon
2007-07-09 by Stefan Trethan
> Leon
Nah, only works on foolish people.
scientifically proven ;-)
ST
RE: [Homebrew_PCBs] Re: Etchants is use
2007-07-09 by Tony Smith
> >     Gingivitis
> Roland F. Harriston
Ha!  :)
Ok, I take it back.  You might a pedantic douche (perhaps reformed since you
trimmed that list!) but it's good to see you've got a sense of humour about
it.
Cheers (& not with a glass of hydrogen peroxide either)
Tony
Re: [Homebrew_PCBs] Re: Etchants To Drink
Tony:
Personally, I don't think I would ever ingest the stuff unless it was
prescribed by a competent
physician, and I don't think that a competent physician would ever
prescribe it for internal use.
But a lot of folks who believe in "alternative medicine" do, along with
a lot of
other "stuff" you will see on the shelves of "health" emporiums that
cater to that ilk.
"Knowledge Is Light"
Socrates (or one of those other dudes said that)
Roland F. Harriston, PD
> > > Gingivitis
> > Roland F. Harriston
> Ha! :)
> since you
> about
> it.
> Tony
Re: Etchants is use
2007-07-09 by Les Kalmus
Always Add Acid means add the acid to whatever. This is a precaution
in case the mixture gets hot and splatters. The splatter will be the
liquid being added to, not the acid.
Les
> <lcdpublishing@> wrote:
> > Jeff,
> -Jeff
RE: [Homebrew_PCBs] Re: Etchants To Drink
> unless it was prescribed by a competent physician, and I
> don't think that a competent physician would ever prescribe
> along with a lot of other "stuff" you will see on the shelves
> of "health" emporiums that cater to that ilk.
The term 'new-age nutters' was coined for a reason.  These days Socrates
might have said 'Light on Knowledge' instead.
Tony
I personally have a theory on that H2O2 thing and oxygenated water:
They need it to counteract all the stuff they take containing antioxidants. ;-)
Maybe people should carry a sign on their mouth along the lines of
"unleaded fuel only" ;-) We are meant to run on what normal food
provides, if you ask me.
But hey, they are just stupid, and generally leaving other people
mostly alone, i don't mind them so much.
ST
On 7/9/07, Roland F. Harriston <rolohar@...> wrote:
> Tony:
> a lot of
> cater to that ilk.
Re: Etchants is use
2007-07-09 by TonyB
Hey Etchers,  mostly lurking, but i've been etching for over 30yrs.
Reguarding the Add-to-H2O discussion:  normally, it's always
recommended to add the acid to the water.  If exothermic (releasing
heat), the water absorbs the heat.  In the cases of H2O2, like in
using sulfuric acid and H2O2 as an organic cleaner for silicon wafers,
i was instructed to add the H2O2 to the (96%) sulfuric.  I've been
using FerricChloride etchant almost exclusivily in my long
etch-capade.  I built a Kustom Spray Etcher a couple of years ago.
It uses a magnetic-drive pump.  I mix my dry (anahydrous) FeCl first
with cold water, then I add hot water.  I use large peanutbutter jars
as measuring/mixing containers.  Probably not a good idea, since they
are NOT tempered glass....guess i've been "lucky" as I've been using
the same jars for over 20yrs!!!  I'm wanting to try the HCL/H2O2
technique for quite some time, but haven't found the time.  I have
several gallons of MuraticAcid, that I use to "rejuvenate" the FeCL.
It DOES work, but makes the solution thicker and harder to pump.  I
burned up my older, adapted swamp-cooler pump.  Now I run a magnetic
drive pump, but have never done any rejuvination.  In addition to the
HCL/H2O2 etching, I want to try rejuvinating the FeCL using
electricity and a CurrentControlled powersupply...Hopefully, by the
end of this summer, I'll have some time for experiments....FeCl seems
to get more and more expensive, which is why i'm looking for an
alternative etching method.  I used to get FeCl for $1 a pound.  YES!
one dollar!! last time, cost about $8 a lb.   If I buy 50lbs, I can
get it for about $5 a lb.  Don't know if the HCL/H2O2 would work with
my spray etcher, but, for one-zee twos-zees, I think the HCL H2O2 will
be a nice quick alternative.  Oh, BTW, I use the LaserToner technique
with the SuperFuser....well, enough rambling.....afn  Tone
> Les
> > > Jeff,
Which to
> > -Jeff
2007-07-09 by lists
In article <000b01c7c1ff$d50cb6f0$4001a8c0@CTHULHU>,
Well, I think some in the list such as Candida, fungal and yeast
infections are external to the body - athlete's foot and that sort of
thing - and bathing the skin with it, in a suitable dilution, may well be
effective in clearing up such problems.
I would certainly advise against drinking it though, in any dilution.
2007-07-10 by Dale J. Chatham
Does wonders for poison ivy, though "bathing the skin" isn't how I'd use
it.
Re: Etchants is use
2007-07-11 by Ted Bruce KX4OM
Jeff,
I've always wondered where one can buy HCl and other chemicals of that
ilk.
Ted KX4OM
> at "room
> > temp"?
> > Thanks!   Jan Rowland
> pardon the bad pun.
> -Jeff
2007-07-12 by Leon
Sent: Thursday, July 12, 2007 12:20 AM
> Jeff,
> ilk.
Some hardware stores sell it here in the UK, for clearing drains.
Leon
