HP 5P Printer?
2008-09-13 by bdrmachine
Has anyone successfully used a HP 5P printer to do toner transfers? I'm using paper from Pulsar with a laminator that they sell (bought from Digi_Key). The tone never sticks properly. Pulsar tech support suggests I increase the Toner density to max. The 5P manual states that the default density setting is 3 of a 1 to 5 scale. I've gone through all the menu options in the printer menu but I can't seam to find any density settings other than econo_mode which I have set to off. I'm using the driver supplied with XP currently but, I also looked at the old 2001 driver HP now has available on there site. I have a new HP brand cartridge install so that is not an issue. Pulsar support also suggested that I check the temperature of the laminator to ensure it is around 270 to 290 C using a temperature probe. The trouble there is that the only probe I can fine is at least .125" around. If anyone can help I will truly be grateful. Brian
