Homebrew PCBs
Drill Code to G-Code
2008-09-14 by bdrmachine
Would someone please explain how to convert the output of the Drill
file to cnc g-code?
I'm using Ares from Labcenter to generate the cadcam output  code.  I
believe it is in rs274x format.  The code has no Z axis motion and no
decimal points like I'm use to seeing in the G-code I normally feed to
my cnc mill.
There is an example of the code that Area's spits out (X+004314Y-
025547).  Is this called Excellon format?
This is what I would type to drill a hole at x=1, Y=2, 0.2 deep: (G01
x1 y2 z-0.2) using G-code.
Thanks
Brian
