Homebrew PCBs
Toner Tansfer PCB photos
2008-09-14 by John Honniball
I recently made my first Toner Transfer PCB, and I have some photos on
Flickr, here:
http://www.flickr.com/photos/anachrocomputer/sets/72157607180910289/
It's an Atmel AVR board, inspired by the Evil Mad Scientist Labs business
card board:
http://www.evilmadscientist.com/article.php/card
I did the PCB design using GNU-PCB and printed the result on
junk-mail paper using an old HP LaserJet 4+ that I got from
FreeCycle.  Etched with Ferric Chloride and then drilled as
usual.
Now I have some plans afoot to make an ATmega32 board, and an
LED shift-register board.
John Honniball
Re: [Homebrew_PCBs] Toner Tansfer PCB photos
2008-09-14 by Stefan Trethan
Wow, didn't your eyes cross drilling all those holes?
At first i thought you etched it on some kind of pre-drilled stripboard...
ST
On Sun, Sep 14, 2008 at 3:29 PM, John Honniball <anachrocomputer@...
> Flickr, here:
> card board:
> usual.
> John Honniball
2008-09-14 by Leon
To: <Homebrew_PCBs@yahoogroups.com>
Sent: Sunday, September 14, 2008 2:29 PM
Subject: [Homebrew_PCBs] Toner Tansfer PCB photos
> Flickr, here:
I've just designed something similar using the new PIC18F24J10, but my board
is all SMT, with just 7 wire links:
http://www.leonheller.com/Designs/PIC18F24J10_Proto.gif
I've made a PCB (photo etch) and will be testing it later.
The next one I make will use the 44-lead QFP 18F45J10. I'll add some
additional pads to that for SO-23 transistors etc.
Leon
Leon Heller
Amateur radio call-sign  G1HSM
Yaesu FT-817ND transceiver
Suzuki SV1000S motorcycle
leon355@...
http://www.geocities.com/leon_heller
What functions do the wire links near C5 and R1 serve? Couldn't you just
connect those directly?
ST
> board
> Leon
2008-09-14 by Leon
Sent: Sunday, September 14, 2008 7:09 PM
Subject: Re: [Homebrew_PCBs] Toner Tansfer PCB photos
I like to have the connections around regulators fairly short, for
stability. It probably doesn't matter, though.
Leon
Date: Sunday, 14 September, 2008, 5:34 PM
Er, yes, it was a bit tedious!
> stripboard.. .
After a while, it did seem like I was etching my own Veroboard!
The next design will have fewer holes, promise.  And I'll use
fibreglass board, too.
John Honniball.
Me too, but if you pull the ground wire corner down right below C5 that one
link is freed up and the trace is the same length.
R1 could be connected directly to conn1, i would say.
Possibly it's just me, hating to solder unnecessary wire links or 0R
resistors.
ST
> Leon
I think they punch veroboard, at least the cheap paper kind.
ST
On Sun, Sep 14, 2008 at 8:28 PM, John Honniball <anachrocomputer@...
> From: Stefan Trethan <stefan_trethan@...>
> > stripboard.. .
> John Honniball.
2008-09-14 by Leon
Sent: Sunday, September 14, 2008 7:43 PM
They aren't etched, either. I think they "plough" out the copper with a
tool, like a shaper with metal.
Leon
Leon Heller
leon355@...
2008-09-14 by Leon
Sent: Sunday, September 14, 2008 7:36 PM
> one
> resistors.
Thanks, I didn't notice that.
I had the DC connector the wrong way round, anyway. Correcting it on the
layout removed that link, of course. The regulator was a dead short when I
first tested it and was taking over 1A. Those little TO-92 devices are very
robust, and it still worked when I turned the connector round.
The board works; I've just tried a test program on it
Leon
Well, the ones i use (if i can't avoid it) have round pads, not strips, so i
think they are etched.
ST
On Sun, Sep 14, 2008 at 9:11 PM, Leon <leon355@...> wrote:
> From: "Stefan Trethan" <stefan_trethan@...>
> Leon
> Leon Heller
> leon355@...
2008-09-14 by Leon
Sent: Sunday, September 14, 2008 9:57 PM
> i
I was thinking of the original Veroboard.
Leon
