Stargate daughter PCB
2009-06-24 by Surf Thenet
Hey guys, Anyone play Stargate at the arcades growing up? The original Stargate arcade boards came with a daughter PCB, a scab used by Williams Electronics to fix a design problem late in production. This is what I am talking about: http://forums.arcade-museum.com/picture.php?albumid=89&pictureid=560 http://forums.arcade-museum.com/picture.php?albumid=89&pictureid=559 http://forums.arcade-museum.com/picture.php?albumid=89&pictureid=558 http://forums.arcade-museum.com/picture.php?albumid=89&pictureid=557 http://forums.arcade-museum.com/picture.php?albumid=89&pictureid=556 This shows the daughter board mounted on the main PCB: http://www.robotron-2084.co.uk/jpegs/R8948.jpg So I need one of these daughter boards; they are of course no longer in production. How much of a stretch of the imagination is it to create one of these one sided PCB's from a picture of a real one? I understand the basics of the toner transfer method: get a reverse image ready, print with laser jet onto cheap glossy magazine paper, iron onto board stock, etch in HCl and H2O2, wipe clean with acetone, drill thru holes. Sounds easy enough, BUT... what software would I use to go from the photo to the reverse image of the final PCB? Will any laser printer work? I took chemistry in school, so the etching does not scare me, how do I drill the holes? TIA, Saltbreez [Non-text portions of this message have been removed]
