2014-05-19 by lilacbarn@...
Thanks Brett, Stefan,'brane2' and Peter for the information provided.
It looks like I shall choose the MB 140/S as others are having success with it and I only want to use it in the vertical.
That video you pointed me to Stefan was impressive in terms of speed of hole drilling, but as you say there is no indication of whether it uses a carbide drill or not ( it was the MB140/S in the video)
Stefan, do you use collets or a chuck for your carbide drills? I note the Proxxon can take either.
It would be good to see your homemade drill press. I have made a Photo album in this group entitled "PCB Drill Presses" where I have posted some photos of the one I made for my Dremel - copied from Delorie - link below.
http://www.delorie.com/pcb/dremel-stand/img_1201.jpg
If you want to share, put some pics there and let us know.
Brett, I would be interested in seeing yours too if you want to put the photos there too.
I also put a photo of the collets that came with the Dremel - they seem to be the major cause of the problems I am having. You may notice in one of the pics that there is a broken carbide drill piece lying on the table. I used the remaining shank of the drill to measure the runout. Even with great care and slow advance, I managed to break three carbide drills in about 4 holes - the runout was so bad with the Dremel 1/8 in collet.
Do any of you think I could fix the problem by buying the Proxxon collets and putting them in a Dremel?
Do they fit? They are steel and have 3 segments.
If the collets do fit and add no extra runout, is 4 /1000 in measured on the collet nut likely to break carbide drill bits?
I notice the Proxxon is spec'd at 3/100 mm which is just slightly more than 1/1000th in. but it does not state if that is the motor/collet shaft or the total system of motor+collet+drill bit.
Stefan, Brett, have you ever measured your runout (at the drill shank)?
Thanks to you all for your quick and helpful responses,
Geoff.
