Homebrew PCBs
DIY Drill press for Dremel type tool
Re: [Homebrew_PCBs] DIY Drill press for Dremel type tool
2015-08-16 by Rick Sparber
Lateral play is critical. Given a drill bit 0.03" in diameter, 0.01" of lateral play can snap it.
Rick
> On Aug 16, 2015, at 7:19 AM, leeleduc@yahoo.com [Homebrew_PCBs] <Homebrew_PCBs@yahoogroups.com> wrote:
> Saw this today and thought it might be useful for PCB drilling.
> Drill press for ~$20
> Anyone who works with wood knows you have to make hundreds of holes for the screws and its almost impossible to make a series of holes perfectly stra...
> View on www.instructables.com
> Preview by Yahoo
2015-08-18 by bobledoux@...
As a hobby builder I drill FR-4 with steel bits. They dull more quickly, but they are cheaper and will not shatter when used in sloppy tolerance hobby tools. Carbide bits require collet chucks in very precise spindle bearings.
I use 1/32, (.032) diameter bits for most through hole construction. These cost about 50 cents each when purchased in 12 or 24 packs from buydrillbits.com. ( I have no financial interest in that company.) The 3/64 bits are used for larger component leads.
Numbered bits are more expensive
2015-08-18 by Harvey White
I invested in more precise drilling equipment, using a Proxxon
mototool with steel collets running on a computer controlled linear
bearing.  (overkill perhaps, but it works well).
I've done #73 carbide drill bits without problems.  You do need to
remember not to move the board itself.
The local prices of carbide bits are approximately 1.00 USD each, but
they will last a long time.
Certain that they are.
I do hand wired vias and mostly surface mount, so my requirements are
probably different than yours.
Harvey
2015-08-19 by alan00463@...
I found a small tabletop drill press (forgot what Proxxon called it) to hold my Proxxon IB/E rotary millilng tool vertical, so I can use it to drill holes in PCB.
IIRC, you can buy it from the vendor that sells the Proxxon tool. It works just like a drill press. It is also made by Proxxon. Haven't used it yet.
Still haven't got a laminator or heat press for toner transfer.
