Homebrew PCBs
SWTPC TV Typewriter replica board project
2015-08-25 by unclefalter@...
Hi there,
I am currently working a recreation of a famous 'computer', the TV Typewriter, which was made by Don Lancaster in 1973. Here's a photo of the prototype:
http://archive.computerhistory.org/resources/physical-object/don_lancaster/X689-86.1.lg.jpg
The unit appeared as a project in the Sep 1973 edition of Radio Electronics. There was a slightly different unit featured on the cover of the magazine (more refined, different keyboard). For a few bucks you could send away for plans to build your own, using either prepared boards (produced by Southwest Technical Products) or by making your own using artwork supplied in the construction booklet, like so:
http://www.swtpc.com/mholley/TV_Typewriter/TV_Typewriter_Reprint.htm
I have pretty much everything I need now to kick off the project, including 1973 vintage chips and the correct MDS keypunch keyboard, to match the prototype. Unfortunately the prototype was, as most are, a one-off, and did not use the boards that were ultimately manufactured or described in the plans. There are no pictures extant of the inside, although talking to Don it sounds like it was fairly close to the kit version in the end.
Anyway, at this stage my best hope for now would be to recreate the boards per the above plans. I'd prefer to do it with period-correct materials (or at least get a period correct look). I'd even like to use period-correct processes (foil tape? I'm not exactly sure how they did it in the old days). But I'm not necessarily opposed to going modern via the toner method.
I guess I am just hoping to get advice. For reference, here are some boards that sold on ebay recently:
http://www.ebay.com/itm/291477123430
It's unknown if these were actual SWTPC manufactured boards or a hobbyist doing their own. It's been speculated by those more knowledgeable than I that it is probably the latter, since the copper traces on the one side weren't tinned, which was normal practice for a manufacturer. They did think that these possibly dated to the early 1970s though.
Anyway, any advice on how to proceed and achieve something visually that looks like these (and hopefully works, too!) would be greatly appreciated.
Brad
Re: [Homebrew_PCBs] Re: SWTPC TV Typewriter replica board project
2015-08-26 by Cecil Bayona
Way back in the late 70s I built a similar unit, the PCB was available then I added all the other parts. I don't remember if it's the same unit, the one I built was by Don Lancaster, it worked great for many years until I replaced it with a commercial unit, a Televideo 950 set to emulate a VT100 terminal by DEC. It was a lot better than my original interface a model 45 later I used a model 33 Teletype unit with paper tape punch and reader. Those were the days if you wanted decent software you wrote it yourself in assembler.
On 8/26/2015 10:14 AM, James Newton jamesmichaelnewton@... [Homebrew_PCBs] wrote:
Cool project Brad!
You have the PCB layouts in the reprint PDFs, just print them out (be sure to set no size reduction) and make sure they fit the components, then transfer to PCB and etch. Lots of ways to do that. Most all are documented here:
http://techref.massmind.org/techref/pcbs.htm
Let us know how it goes.
Cecil - k5nwa
http://thepartsplace.k5nwa.com/
RE: [Homebrew_PCBs] Re: SWTPC TV Typewriter replica board project
2015-08-26 by Brad
Thanks muchly guys.
I guess being new to the art of PCB fabrication, I’m trying to figure out how I could get as close as possible to the appearance of the (we think) vintage boards seen in my ebay link.
When I asked Don Lancaster about the boards he used in the prototype, he said this:
“The original boards were G10 green. Original artwork was 4x tape and dots followed by litho camera reduction.”
I guess my question is, can I get green copper clad boards that look like the ones in my photos?  I’ve read through the laser toner process and it seems to me if I get boards that visually look similar the end result shouldn’t be that much different if I use a newer (easier) process.   But in looking around ebay, etc I’ve not seen anything that has quite the right vintage look.
I’m also curious as to how the person that created those ebay boards got all the markings in white on the top side (ie. the SWTPC logo, transformer footprint, etc).  Any thoughts on that?  I’m guessing Don didn’t have anything like that with his prototype boards.
Speaking of which, I may get an answer on what the prototype boards actually look like.  I emailed the research department of the Computer History Museum that has that unit, and they offered to attempt to open it to have a look, provided it was designed to be opened and no damage will happen.
Brad
2015-08-26 by Harvey White
On Wed, 26 Aug 2015 14:54:24 -0700, you wrote:
>Thanks muchly guys.
>I guess being new to the art of PCB fabrication, I\ufffdm trying to figure out how I could get as close as possible to the appearance of the (we think) vintage boards seen in my ebay link.
Ok....
>\ufffdThe original boards were G10 green. Original artwork was 4x tape and dots followed by litho camera reduction.\ufffd
That's the camera process and photoetched.
>I guess my question is, can I get green copper clad boards that look like the ones in my photos?  I\ufffdve read through the laser toner process and it seems to me if I get boards that visually look similar the end result shouldn\ufffdt be that much different if I use a newer (easier) process.   But in looking around ebay, etc I\ufffdve not seen anything that has quite the right vintage look.
Ok, not a quite easy thing to do.  Most boards are generated from
Gerber files.  When those boards are done, they have silk screen,
solder mask, and plated through holes done.
Laser toner will give you a duplicate of the pattern, but will not do
plated through holes, nor will it do silk screen.  (you can do silk
screen, and it is possible to do  solder mask, but it will involve a
process for each item.)  Plated through holes are very very rare to
achieve.
>I\ufffdm also curious as to how the person that created those ebay boards got all the markings in white on the top side (ie. the SWTPC logo, transformer footprint, etc).  Any thoughts on that?  I\ufffdm guessing Don didn\ufffdt have anything like that with his prototype boards.
Silk screen through toner transfer (see pulsar website) is quite
possible *if* you use toner transfer at all.
Depending on the tools you use to make the boards, you can get quite
close.
Let me explain a bit, since it's not obvious at first glance.  The
problem is the traces themselves.  In tape generated boards, the
draftsman did the curves by hand, and often did curves all over the
place (look at old Tektronix boards).  Ground pours were not all that
common.
In computer generated boards, you get mostly straight lines unless you
take pains to allow curves, (and that most likely means no
autorouters).  You can get a ground pour quite easily.
You ought to get results, then.
Harvey
>Brad
