Homebrew PCBs
PCB Mini-Factory
PCB Mini-Factory
2016-01-19 by Steve Greenfield
This is awesome! Mainly 3D printed parts, aluminum extrusion, and Acme screws. Uses standard Arduino Mega with RAMPS 1.4 and A4988 boards. I think they should have printed a project case with it instead of a frog.https://youtu.be/rDTOBbg9ZXU
Published on Feb 22, 2015Diyouware TwinTeeth is a PCB mini-factory targeted to the electronic hobbyists.
http:\\www.diyouware.com
It is an innovative PCB fabricator which will helps us to make PCB prototypes at home. It includes the following functions:
- UV Laser photoengraving – drawing the circuit on sensitive film or board using an ultraviolet laser.- Drilling –vias and holes using any mini-rotary tool like Dremel or Proxxon.- Solder paste dispensing – deposits solder paste with precision on SMD PCB pads.- Plotting – plots the circuit with a permanent pen-maker (if you prefer this method).- 3D printing – and make knobs, casings, front-panels with PLA or ABS. Also prints circuits with conductive filament, or makes circuits supports.- Milling/Carving/Etching – soft materials or etching PCB copper with a v-bit.- And much more… because it is extendable and you can use any other tool you can fix on it.
More info on www.diyouware.com
 Steve Greenfield AE7HD http://www.linkedin.com/in/stevenjgreenfield
