None of the profiles supplied for any printer are designed for digital negatives. You will always have to create your own. Start with the text file from Ron's book.
Or here is a Pt/Pd profile that I created for the R3000:
Copy it into the R3000 folder and run the install program. Follow the steps in Ron's book to establish your printing time, print a step tablet and linearize the midtones. You will probably have to adjust the ink levels for Cyan and gum.
Good luck
On Feb 3, 2012, at 9:39 AM, Norman Christie wrote:
> Thanks for replying Alan,
> Yes it is Ron Reeder's book that I am working from . Unfortunately the book, whilst useful, is written using CS 4 and the R3880. I emailed Roy Harrington about there being no .quad files in the Epson R 3000 library and he admitted that to date none have been written and suggests I try some of the other Epson drivers. This what really frustrates when programs state that they support a particular model. I will look for Clay Harmon's messages
> On 2 Feb 2012, at 21:24, Alan Vlach wrote:
> Regards,
> NormanC
# QuadToneRIP curve descriptor file
# for R3000 UC inks
# Revere Platinum
# TPF100 Ink limit =60
N_OF_INKS=8
DEFAULT_INK_LIMIT=100
Print_Curve=Yes
LIMIT_K=17
BOOST_K=25
LIMIT_C=17
LIMIT_M=17
LIMIT_Y=17
LIMIT_LC=46
LIMIT_LM=0
LIMIT_LK=46
LIMIT_LLK=46
# Describe usage of each ink
# All inks must be listed
# Gray Partitioning Information
N_OF_GRAY_PARTS=2
GRAY_INK_1=K
GRAY_VAL_1=100
GRAY_INK_2=LK
GRAY_VAL_2=33
GRAY_INK_3=
GRAY_VAL_3=
GRAY_INK_4=
GRAY_VAL_4=
GRAY_INK_5=
GRAY_VAL_5=
GRAY_INK_6=
GRAY_VAL_6=
GRAY_INK_7=
GRAY_VAL_7=
GRAY_INK_8=
GRAY_VAL_8=
GRAY_HIGHLIGHT=0
GRAY_SHADOW=10
GRAY_GAMMA=1.3
# GRAY_CURVE=
COPY_CURVE_C=K
COPY_CURVE_M=K
COPY_CURVE_Y=K
COPY_CURVE_LC=LK
# COPY_CURVE_LM=LK
COPY_CURVE_LLK=LK
