Initial Calibration issue QTR and UT14 on Epson Premium Photo Gloss.
2013-02-09 by rossfmj
I am having a big problem trying to create a profile for Epson Premium Photo Gloss. Every time I set an ink limit, regardless of value, when it comes to measure a 21 step wedge for linearisation, I find that the last two (darkest value) steps appear to have lower density values than the lighter steps. It seems that somehow there is a feedback problem within the process I am using, but I can't imagine where this may be. For example: Printing out the inkseparation6.tiff file via QTR print, with no color management I measured density values which indicated an ink limit of 75%. I then reprinted the inksearation6.tiff to calcualate the gray value, which was 35%. I was using Cyan, Cool Photo black and Light Cyan, Dilute cool photo black, to get a cool profile. I then install the profile, without linearisation details. Next, when printing a 21 step wedge to linearise the profile, I then find that the maximum density value is about 90% and declines for the next two steps. I have repeated all these steps several times and have even gone down to an ink limit of 45%. However every time I've tried to create a linearisation file I find that the darkest steps have a density value lower than 90%, which seems to have the maximum value. The advice from tutorials suggests to set the ink limit at the point where the initial density values reach a maximum. I.e. if the measured density values are 2.00 at 60%, 2.01 at 65% 2.01 at 70%, then 65% should be the set ink value. Initially I followed this procedure to set the max ink value. I now think that instead of aiming for the maximum density value, I should go for the maximum density value reached by steps of .02 instead of 0.01. so if the steps go up such as, 2.00 for 50%, 2.04 for 55%, 2.05 for 60%, 2.06 for 65%, 2.07 for 70% 2.08 for 75%, I should set the ink limit at 60% and no higher. However, following this rule, when it comes to linearisation, I find that the top one or two density values are still lower than 90 or 95%. It is getting beyond frustration point now. I think the next step is to remove all programmes and start afresh. I seem unable to get to the point of linearisation, so would appreciate any help. Ross
