Hi Gary,
I'm just back from the Golden Trout Workshops; so please excuse the delay in
respondin
> I have been using UC inks in my 2880 but I'd like to break out my 2200
> and add MIS inks to enrich my BW images. I use Moab Entrada but I feel the
> need to have a bit more Pop or snap where the Entrada has a softness to it.
> I also need a paper with a substantial weight to use for my portfolio.
> Please make a suggestion on paper and ink combination for the 2200. I'll
> start by using it with my 2880 then move to the 2200. Is the same choice
> good for color?
> It's hard to make a recommendation without knowing the tones, etc. that are
the target.
In general, I don't think you can do better than a 2880 if both color and
B&W are the goal.
For dedicated B&W the 2200 is still a good machine if it's working well.
The MIS UT7 was the variable tone inkset I designed for it. Today for
maximum smoothness and longevity of the image, I'd probably go with 100%
carbon (Eboni-6) or, if more neutrality was needed, Eboni-4 Plus (see
http://www.paulroark.com/BW-Info/Eboni-4-Plus.pdf ), but that would require
some work by you to make profiles.
In short, there are a lot of variables.
