Tom,
> Will it make a big difference if I linearize the EB6-EpsHPn curve (or for
> that matter any other curve) to my 1400 printer? I'm very happy with the
> results so far but am just curious.
If inksets, paper, printers, and spectros were all exactly uniform, it would
make no difference if you re-linearized the profile. Of course, none of
these things are perfect, but most find that they are within acceptable
tolerances. I might add that I was very pleasantly surprised when I
measured the draw down values of the last batch of MIS Eboni-6 I received.
Also, what's the "T" designation in EB6-EpsHPn-T?
On profiles with the "T" added I took half of the inks and put them into a
"toner" channel. This way there are more overlaps. For example, in the
lightest parts of the print, instead of just the 2% Eb6-Y firing, both it
and the Eb6-LM (6%) are operating. With the 1400 both of these inks are
dotless. The downside of this if you want the most neutral print is that
the change in Lab B goes from 1.5 for the standard profile to 2.3 for the
"T" profile. See the Notes tab in the profiles.
Hope this helps.
