Analogue-sequencer
Index last updated: 2026-04-28 23:15 UTC
eventual Cirklon documentation
2011-05-05 by tmoravan
Colin - being a sw developer myself, I know that documentation is often the last thing on the list and the most loathesome of tasks.
I have a proposal - would it be possible to provide a general outline of a document in some standard format (MS Word for example), along with pointers to existing P3 docs (if applicable), and then have the community create the user manual with you doing the proofing and corrections if we document a feature incorrectly?
Also - if there was an easy way to do screen captures on the Cirklon, that would go a long way to making the doc more usable.
The way I see it, people could sign up for a feature or menu and document it extensively and then you could stitch the pieces together and we might then have a useful document quicker than if the burden fell solely on you.
Thoughts?
Re: eventual Cirklon documentation
2011-05-05 by ianmantripp
How about setting up a wiki instead of MS Word... much more sharing friendly ;-)
Ian
> Thoughts?
--- In analogue-sequencer@yahoogroups.com, "Colin Fraser" <colin@...> wrote:
> The idea of Wiki-based documentation does appeal.
> Not as the sole source - I fully intend to print up manuals.
> A ring binder containing a snapshot of Wiki-based documentation in a
> print-friendly format might be the best way to go.
> I have no idea how I would go about setting up a wiki.
> I guess I need some server-side scripting and a database.
> It's been a long time since I did that for a living.
There can be setup and hosted free here: <http://www.wikidot.com/>
Never done it though so I don't know if it's a good service. Maybe someone else has some experience with such a service provider ?
Ian
Re: [analogue-sequencer] eventual Cirklon documentation
2011-05-05 by Mark Morton
While I appreciate the videos, I would like to add my voice to the chorus -I
rely on documentation in learning instruments and i find that , even for
boutique intruments, , lack of or poor documentation can often harm the
product well beyond the developers expectation. Other than a complete os I
think that documentation that is adequate is the single most important thing
to me and many others I know. If an outline can be produced, I am a drafter
and can edit some narratives as time permits 9 after i get my machine of
course)
> Thoughts?
pardon my ignorance, but is there an easy way to go from an on-line Wiki format to a double-sided 8.5x11 (or A4) printed format that can be put in a ring binder and used without a computer nearby?
--- In analogue-sequencer@yahoogroups.com, "ianmantripp" <ianmantripp@...> wrote:
> Ian
RE: [analogue-sequencer] eventual Cirklon documentation
2011-05-05 by Colin Fraser
Possibly more accurate to say it's the first thing on the list, but the last
to get done :-)
I have some sections of the Cirklon manual started, and a rough idea how I
will put them together.
The main problem getting it done is that a user manual is a snapshot of the
functionality at the time of writing.
I keep adding stuff, so the manual is going to be out of date the day after
I finish it.
I need to stop adding stuff for a bit, and write down what's there already.
If you've seen the tutorial video on Youtube, the close-up view of the
display is actually a web-cam capture of a second display located behind my
Cirklon, slaved to the main display raster signals.
I can take native resolution screen-captures directly from that in GIF
format, inverting the colour to suit printing better.
That bit shouldn't be a problem.
Best regards,
Colin Fraser
Sequentix Music Systems Ltd
http://www.sequentix.com
2011-05-05 by Paul Nagle
Please don't. Happy to help folks through the early days of their
machines as you continue doing things. Which reminds me, I was meant to
verify some Logic/USB MIDI tests... :)
http://www.softroom.co.uk
http://www.youtube.com/WilyEPeyote
RE: [analogue-sequencer] Re: eventual Cirklon documentation
> computer nearby?
That would probably be a manual job for me.
Best regards,
Colin Fraser
2011-05-06 by ianmantripp
The wiki is not meant to be a replacement for a printed (or pdf) manual, but as an easy collaborative information sharing and writing tool.
Getting the data from the wiki into a page layout application may actually be easier than you may think. Using XSTL (xml transformation) or a custom db export to xml script, the data can easily be reused... how easily depends how the db is setup.
I have written such a script before which also added the InDesign styles markup. Once the layout template is made and styles defined, they just imported the xml and hey presto... the manual... well in that case in was a magazine.
Ian
2011-05-06 by Colin Fraser
> and writing tool.
That's how I was looking at it.
Sounds simple...
Best regards,
Colin Fraser
2011-06-02 by dede
+1 for a collaborative approach, +1 for a wiki.
perhaps a reader-friendly, printable PDF can be assembled afterwards.
though english isnt my native language, I'd love to contribute some content.
cheers,
roman
> Ian
> > Thoughts?
2011-06-12 by dede
i've researched a bit about wikis.
here you can can compare wiki systems, look for XML/PDF export: http://www.wikimatrix.org/search.php
wikidot does not support XML export.
the tracker guys from renoise.com have a mediawiki-generated PDF manual: http://tutorials.renoise.com/wiki/Main_Screen (PDF link: left sidebar at the bottom)
wikipedia is based on mediawiki, so it surely won't be abandoned in near future. for installation PHP 5.0+, mySQL 4.0+ and phpMyAdmin (webbased DB-client) is recommended.
cheers,
roman
> > computer nearby?
> Best regards,
> Colin Fraser
2011-06-12 by dede
I'd help with the technical part, we have mediawiki at work too (I work as a web programmer).
--- In analogue-sequencer@yahoogroups.com, Ian Mantripp <ianmantripp@...> wrote:
> On Sunday 12 June 2011 at 10:18, dede wrote:
> > the tracker guys from renoise.com (http://renoise.com) have a mediawiki-generated PDF manual: http://tutorials.renoise.com/wiki/Main_Screen (PDF link: left sidebar at the bottom)
>  That is very nice !!
> Colin, I am willing to do some work on graphics if required. Just let me know.
> Ian
2011-06-12 by Colin f
Thanks Roman, I'll have a look at it.
Colin
> From: analogue-sequencer@yahoogroups.com
> [mailto:analogue-sequencer@yahoogroups.com] On Behalf Of dede
> Sent: 12 June 2011 09:18
> To: analogue-sequencer@yahoogroups.com
> Subject: [analogue-sequencer] Re: eventual Cirklon documentation
> (PDF link: left sidebar at the bottom) wikipedia is based on
> cheers,
> roman
> > > computer nearby?
> > Best regards,
> > Colin Fraser
Re: [analogue-sequencer] Re: eventual Cirklon documentation
2011-06-12 by Ian Mantripp
Ian
2011-06-16 by dede
just to let you know: I've set up a test wiki environment (mediawiki), link and discussion can be found at the cirklon-beta group.
cheers, roman
