issue firing clips in ableton with bcr2000
2008-08-20 by robleighton22
hi again,
im beginning to make progress with my bcr2000. configuring direct
form the bcr is actually quite easy, now i understand the
instructions in the manual (im a complete midi noob). i at last setup
cc's on every knob/button and hav almost made a worthy preset for
live. except one majorish issue. i want to use buttons to launch
clips.
button 1 is say set at cc# 60, toggle off, on parameter = 127, off =
0, ch 1
when i map the button to a clip and then come out of midi map mode,
the clip is constantly re-launching without me even pressing any
buttons. in fact the only way to stop the clip is to go back into
midi map mode.
so then i change it to toggle on, still get the same issue, also if i
change the on/off parameters, it still happens.
everything else seems thing.
i can toggle mutes, solo's, etc. and also select tracks and toggling
on/off works fine for other functions other than launching clips. i.e
i have toggle off for beat repeat, so i can hold it down like note
repeat function on an mpc. pretty good.
any ideas what im doing wrong when mapping clips?
thanks
