IF IT'S NOT ONE !#$$%$^! THING IT'S ANOTHER....
2008-10-20 by libraclassic2
MY DEVICE MANAGER RECOGNIZES MY BCF2000, BUT NOW MY @!$%$%!#$ PROGRAMS
WON'T.  NONE OF THEM.  ALL THEY SHOW IS THAT MIDI YOKE CRAP AND MY
SOUNDCARD (LINE 6 TONEPORT UX2).  DOES MIDI YOKE OR HUSKERVU HAVE
ANYTHING TO DO WITH THIS?
Device Manager recognizes my BCF2000, but now my !$#$%@ programs
won't.  None of them.  All they show is that MIDI Yoke crap and my
soundcard (Line 6 Toneport UX2).  Does MIDI Yoke or Huskervu have
anything to do with this?
And why the hell does my Behringer disappear everytime I reboot?  I
have to reinstall the !%$!$ thing everytime i start the dam thing up.
 I had to switch USB ports in order for my system to recognize what's
alternately looking like a godsend and a piece of shit all rolled into
one.
Re: IF IT'S NOT ONE !#$$%$^! THING IT'S ANOTHER....
2008-10-21 by Erik Hines
You shouldn't be using Midi Yoke, at least for the setup you described
to me. Midi yoke screws up port mappings in Cubase as it 'takes over'
the midi port. I haven't needed Midi Yoke or Husker Vu EVER in my MIDI
setup, which I control over 15 devices.
Also, I only use MIDI OX when I'm doing sequencing outside of CUBASE,
Midi OX also 'Takes Over' the midi port, so I DO NOT USE THEM AT THE
SAME TIME!!!
MIDI OX"S port mapping system is great, and you should have no problem
with multi patching devices. And Midi YOKE is bad as it installs those
nasty "Virtual Midi' devices, that can cause some issues down the road.
In Cubase, you can also route midi ports to multiple midi outs, so I
see no need to have Midi Yoke AT ALL!!
My advice, uninstall Midi YOKE and Husker VU. Open up cubase and try
again. Also, spend MORE TIME WITH MIDI OX, LEARN ALLOF IT"S FUNCTIONS
BY GOING THROUGH EACH OF THE ICONS. You have a number of different
functions that will help you troubleshoot. Also, open up the '66'
icon, that your Midi Patchbay, you can route 1 input 10 10 outputs or
vice versa, very helpful.
Erik
> one.
2008-10-29 by islandgroove2002
If all else fails, uninstall the USB Behringer drivers and get
yourself another midi interface to plug the Behringer into. I never
had any luck with the Behringer drivers.
As far as Midi Yoke is concerned, I don't really see why you would
need to uninstall it. I have used Midi Yoke extensively with lots of
mixed midi gear and have never had a problem.Midi yoke etc gives lots
of options for midi routing that you would never get to use otherwise.
described
over'
MIDI
CUBASE,
> SAME TIME!!!
problem
those
road.
FUNCTIONS
or
> Erik
> --- In bc2000@yahoogroups.com, "libraclassic2" <libraclassic2@>
PROGRAMS
I
up.
what's
into
> > one.
2008-10-29 by diddywahdiddy1
--- In bc2000@yahoogroups.com, "islandgroove2002"
Same here: I had no luck with the drivers. Everything went nuts. I
simply uninstalled the drivers and have had no problems ever since. The
software (reaper) recognizes a usb audiodevice and has no problems
whatsoever.
2008-11-01 by Mark van den Berg
Since so many people (including myself!) have had all kinds of
problems concerning the USB drivers for the BCx2000, I've been
planning to publish a BCx2000 USB guide (containing a feature
comparison, installation procedures, troubleshooting etc.), but I
don't know if and when I'll be able to finish that document, so until
then I'll just mention a few of the most relevant points:
If you CAN get the "latest" Behringer driver, vs. 1.2.1.3, to work, I
recommend using it, because it has several advantages to the standard
Windows "USB Audio Device" and the earlier Behringer USB driver versions:
- "USB Audio Device" is "single-client", i.e. any of its MIDI input or
output devices can only be connected to ONE computer program at any
moment in time. By contrast, the Behringer USB drivers (all versions)
support a virtually unlimited number of simultaneous connections.
(Depending on my computer setup, I've managed to run 60 to 90 clients
simultaneously!) So for instance if you're using BC Manager to define
a preset for connecting your BCx2000 to a sequencer program, you don't
have to quit BC Manager before starting the sequencer program: you can
simply keep BC Manager running.
- "USB Audio Device" has very confusing input/output device names.
This becomes especially relevant if you have more than one BCx2000.
- In operation mode "U-4", the older Behringer USB devices (1.1.1.0
and 1.1.1.1) produce the wrong name for MIDI output port B, specifying
"A" instead of "B". So e.g. in U-4 the device "BCR2000 [01] OUT A* is
ACTUALLY linked to MIDI output port B on the BCR.
By the way: it IS possible to install any Behringer USB driver under
Windows Vista: if you try to run any Behringer USB driver's installer
(e.g. bcr2000-driver-setup.exe for vs. 1.2.1.3) NORMALLY, the
installer fails with the message "invalid OS version" (or so), but
these installers DO run if you first set their "Compatibility mode" to
"Windows XP (+SP2)" on the "Compatibility" tab in the file properties
dialog box.
One word of warning concerning MIDI Yoke: any ENABLED Yoke input or
output device causes a delay of about a quarter of a second during
termination of BC Manager. (I SUSPECT this delay is simply a feature
of MIDI Yoke.) So if you have enabled all 16 MIDI Yoke input and
output ports in BC Manager, you get something like a 2 x 16 x 250 msec
= 8 sec delay, which isn't nice.
I haven't tested yet if this delay also occurs in other music software
(Sonar, Ableton Live or whatever) if you enable the MIDI Yoke ports in
these programs; my suspicion is that the same thing happens (if not,
it might be BC Manager's fault after all...).
Anyway, the moral is this: if you're using MIDI Yoke and BC Manager
together, you should disable as many MIDI Yoke ports in BC Manager's
"MIDI devices" dialog box as possible. Basically you should disable
ALL MIDI Yoke ports, except possible one or two you're specifically
using in BC Manager itself. (Note that you can of course still use
these MIDI Yoke ports in other programs.)
Mark.
