New BCF2000 Owner.
2008-10-20 by Jim Gray
Hi, I have had this BCF2000 for a month or two now. I was using preset 1 in Ableton Live. It was sort of working but the 16 buttons and 4 lower buttons were set to toggle on and off. I want to use them to trigger clips and the start, stop and other transport features in Live. I went in and manually changed the button to MMC and now they do not work any more. I downloaded the Java app and reset them back to the default setting. Ableton still will not see the buttons properly. And after I put Ableton into Midi config mode the BCF2000 stops sending Midi data but can still receive it from Ableton. I upgraded from 1.07 to 1.10 to see if that would help but it still does not work properly. I would like to know if there is a way to reset the device back to factory default and what the proper setting is for the buttons to be used to trigger instead of toggle? Thanks Jim
