MCE mode : bcf delay/latency
2009-01-07 by nedaggg
Hello. When I use my bcf2000 in mackie mode on Cubase sx 3.1  there's lot of delay/latency . If I move a fader , it returns to positions and after some tweaking of knobs and mainly press function keys  the bcf almost do not respond anymore . When I use in BC mode instead everything goes fine , faders follows automation in real time .I noticed that another generic remote Preset from behringer (simple mixer )used in bc mode caused about the same  delay  I'm using Vista , firmware 1.10, Core duo , 1 Gb memory.  Any check-list suggested to solve this problem ? It seems to be any config issue . Thank you. Denis
re: MCE mode : bcf delay/latency
2009-01-10 by nedaggg
Hello
Anybody using bcf with cubase sx3.1. ???   Any advices are welcome !!!
Re: MCE mode : bcf delay/latency
2009-01-11 by k5kip_1999
Are you using a virtual lcd?
How are you routing your midi from bcf?
Have you tried the other bcf preset for Live, here in the filse
section?  I think it is Mago's.
I know you are not using Live, however, many, not all, of them mackie
commands are the same across daws. It might help to eliminate some
variables.
Kip
> Hello
2009-01-12 by nedaggg
Hi kip_1999
Virtual lcd - I tried and it crashes more and more and then decided not to use , no ok
Routing - usb , do you think if I route via midi on my m-audio fast track could solve the problem ?
 I tried other preset from file section (preset "bcfmce") and it worked , because its not mackie but GM so I don't get many controls like inserts neither eq .  (Magos couldn't be downloaded I will try again) . Does magos provide control over eq ?
But most important I took the bcf to a friends house where I tested in MCE  with cubase 4 and vista and wow it worked really nice !!! So it is something with my setup maybe asio 4all  , I will try reinstall cubase and drivers again
Any comments are welcome
Denis
> variables.
> Kip
> > Hello
> keys  the bcf almost do not respond anymore . Wbbhen I use in BC mode
2009-01-13 by k5kip_1999
So your routing is bcf > to DAW software?
Mackie Control surface input
Mago's is designed for Live... Some of the commands set will need to
change.
Most of it will work.
I don't know if eq works, I don't have cube, except for a very old
version... and it is not installed.
> Hi kip_1999
not to use , no ok
> Denis
> > variables.
> > Kip
> > > Hello
welcome !!!
Denis
