Please let me know if/when you do.
I will add them to the presets I have done.
Kip
--- In bc2000@yahoogroups.com, "lorcan_music" <lorcan.mcdonagh@...> wrote:
> Thanks for your tips !
> But I guess Behringer have a programmed more stuff in MCU mode,
> because Cubase does send updates to the controller everytime you
> change a value directly on screen with the mouse in the software.
> For example, the led rings are updated to reflect pan settings.
> I just thought it might have been possible to do the same with
> BCManager and BC mode but I haven't found a solution (yet ?)
> Thanks
> --- In bc2000@yahoogroups.com, "k5kip_1999" <k5kip_1999@> wrote:
> > LEDs - on mackie emulation for pans/vpots.
> > You won't get them. The vpots output relative midi data.
> > Turn to the left they output 65s or some value close but above that
> > depending on how fast you turn the knob.
> > Turn to the right the out put 1s or something up to about 10 depending
> > on how fast you turn.
> > The leds don't know what to do with that. You can try to enable them
> > but they won't reflect correct positions.
> > The buttons are possible.
> > Look at the bcr live preset 5.0a and you can copy buttons to the bcf.
> > You can copy knobs as well.
> > --- In bc2000@yahoogroups.com, "dapelikan" <lorcan.mcdonagh@> wrote:
> > > Hi all,
> > > first of all thanks for the great and detailed information available
> > > here, it is really invaluable.
> > > I'm using Cubase4 with a BCF, and naturally i started to use MCU
> > > emulation. However, i was a bit frustrated to see many buttons
are not
> > > used in Cubase, and some are assigned to functions i do not need or
> > > are too complicated to use (especially the shift+button ones which
> > > require you to have giant's hands).
> > > So i looked around to see wether it was possible to try and
implement
> > > a custom MCU emulation that would suit my needs better.
> > > I found these pages
http://www.arthunkins.com/Behringer2MCUPresets.txt
> > > and http://www.arthunkins.com/Behringer2MCUPresets.zip which
were very
> > > helpful.
> > > I modified the .syx files opening them with BCMan to change button
> > > assignments. It worked partially, but I couldn't get the led
rings to
> > > display pan values and update correctly, neither did I manage to get
> > > the button leds to reflect the software status. This works fine in
> > > 'native' MCU mode, so i thought maybe it would be possible to
achieve
> > > the same with BCMan.
> > > Also sometimes the faders are not initialized. I changed the
> > > connection from usb to MIDI and this seems to fix it ...
> > > Any advice, please ?
> > > Cheers,
> > > Lorcan
