> Hallo,
> Same error exactly here but no unit responce, possible hardware malfunction after a serious power failure. Unit is out of order completelly, without the possibility of resenting. Is there a possible explanation? What do I have to check at first (inside electronics / power circuit), to find out if there is a chance for an expert to fix it? any ideas welcomed, thanks.
> --- In bc2000@yahoogroups.com, "rpcfender" wrote:
> > Hi
> > What mode are you trying to operate it in?
> > Try pressing and holding the top left button while powering the machine on. This should put it into BC (non-emulation) mode.
> > Now it is in this mode, load up Mark's editor and have a look at the global settings and the presets.
> > OR if you are still in trouble try the panic reset - Push & hold EDIT press EXIT.
> > Let me know what happens
> > Royce
> > > My unit seems to lock up when I power it on. It's OS v1.10 blinks in the LCD screen, and the unit is in-operable. If I push store/exit, I can initialize it and the unit works, and can be programmed. But if I change programs or power it off, the unit goes back to it's flashing status, and I have to start from initalize again.
> > > Is there a battery in this thing that's causing this?
> > > I re-installed 1.07 using update utility via mids/sys. Same problem.
> > > I installed v1.10 and the same problem happened. Both times the sys-ex dump was successful.
> > > Any thoughts? I'm screwed right now, any help is much appreciated.
> > > Thanks,
> > > Dallapicolla
