> First you need to go into the MIDI menu on the JX8P and turn System Exclusive [#26] on.
> I can really only speak for the Mac side of things, but you should be able to use something like Sysex Librarian http://www.snoize.com/SysExLibrarian/ and just drop the .syx file in, change the destination to your BCR2000 Port 1, and then click "Play".
> For this, I put the BCR2000 is in "USB Mode" because it's easiest. The modes are changed via hitting Store+Edit on the BCR then turning the top, leftmost knob until it reads U-1 through 4. I've not used USB mode to control the JX, only to dump SysEx, but Standard mode (S1-4) using regular old MIDI cables works perfectly.
> If you're using a PC, maybe someone can chime in with whatever software works best/easiest for them but the process should be roughly the same?
> I mostly typed all of this out for posterity, in case anyone needs it, but I'm pretty confident that you can find all of this information a few times over with a little diligence.
> On Dec 30, 2012, at 5:12 AM, stephen wrote:
> > Thanks for the reply, ive done this but i have no idea how to get the preset on the bcr2000? Im a serious noob at this, I have owned one since 2006 but have only recently needed to be using it with hardware
> > Thanks
> > --- In bc2000@yahoogroups.com, "aaron.schepler" <aaron3900@> wrote:
> > > I am using the preset that Rainer, from this group, created. It can be found in the "Files" section of this group. Just click on the "Files" link on the left-hand side of this page. :-)
> > > --- In bc2000@yahoogroups.com, "stephen" <straightola@> wrote:
> > > > I don't have an answer but what's preset are you using? I'm a bit of a dope and have not been able to load any, my mac can't open the software as its too old so would be great to know your method
> > > > > Hello all,
> > > > > I'm new to the group. I've downloaded and just started enjoying the JX-8P preset, which I've installed on my new BCR2000. I have a couple of questions:
> > > > > 1) When I turn the encoders on the BCR, is the display on the JX-8P supposed to change and show the parameter that I'm editing (and the corresponding values)? It doesn't do that now. The number next to the name of the selected patch flashes, showing that it's being edited, but that's all.
> > > > > 2) On the BCR itself, the digital display always shows a range of 0-127 when I turn the encoders, even if the range on the JX-8P is different (e.g., 0-3 for at least one parameter). Is this normal?
> > > > > Thanks in advance; I really appreciate the fine work that's been done to create these presets!
> > > > > Aaron
