Hi
---> I would like to tweek for
> example Kore 2 from NI, 8 knobs. They
> give great effect by using a mouse but here is where the BCF could comes in. I
> have panning and volume in Sonar.
> Wich preset from Berhinger to you mean?
bcr_Only_Controllers.zip
Down the bottom of the page are a bunch of presets
http://www.behringer.com/EN/Products/BCR2000.aspx > I can load the Pro 53 from NI preset and that is the only one who works. I still
> read on the net that people use for example
> Massive from NI, they won´t tell how, so it should be possible.
You don't say what DAW you are using. Abelton Live can give you more flexibility as far as Midi channels in the CC
Select the CC preset on the BC
Start Massive in the stand alone version.
Set up Massive with Midi input from you keyboard and the BC.
Right click on a Massive knob and you will see 'Midi Learn' - select that
Twist the encoder you want to use and the Massive knob should move and now this knob will be controlled by the BC. Massve turns off Midi learn for that knob once it has a valid CC.
Right click the next Massive knob and repeat.
Save the settings File/Options Midi tab
Load this file the next time you start Massive.
In Live you will need to have the BCR on in at least the 'Track'
> Where do i get the BC Midi Implementation Manual, the document of BC by Royce
> Craven and the BC manager?
BC Midi Implementation Manual and BC manager from Mark's excellent web site.
http://home.kpn.nl/f2hmjvandenberg281/ My document is in the Files section of the group in the Documentation folder and is called Secrets.pdf because Behringer wouldn't tell us about the extra stuff in the BC.
Secret.pdf location All the best
Royce
