How to make a button 'toggle'?
2010-09-26 by sweetbreeder
I just got a BCR2000 and I'm making templates for some softsynths I have. I'm trying to set up some of the buttons to have a 'toggle' function for more values than 2, instead of on/off switch. For example changing mono/poly/legato modes. I tried setting upp CC value with 'increments' in Controller Mode and 'Steps: 3' in Controller Option, but that didn´t seem to work so well. How would I do this? Is it possible?
Re: How to make a button 'toggle'?
2010-09-27 by Royce
Hi
you will have to tell us the values you want to send.
if it is something random like 2, 24 and 17 then you are out of luck, but if it is a sequence 0,1,2 or 3,7,11 you could be ok.
Show the whole message
Mono    CC15 3
Legato  CC15 1
Poly    CC15 5
Legato is usually independent to mono/poly.
You can have Mono/Poly and Multi - the EMU Preteus 2k etc
It looks like you are on the right track.
All the best
Royce
2010-09-27 by sweetbreeder
Thank You,
I solved it, I confused the on and off values, it should be highest on 'on' and 0 on 'off' and then I set the step value to match the up value dividable by three, works fine now.
I was making a template for the Minimonsta which maps Legato/Mono/Poly to the same control. Thanks for the reply though!
--- In bc2000@yahoogroups.com, "Royce" <rpcfender@...> wrote:
> Hi
> Mono    CC15 3
> Legato  CC15 1
> Poly    CC15 5
> All the best
> Royce
